hi iv got a bleed valve under the bonit and an in car boost if i wind the one under the bonit out will the one in the car be less sensitive because the valve in the car i used to unwind it round twice for 20psi. but now it only needs to be un wound once for 20 psi. so what im saying is i want it less sensitive in the car as it was befor some one played about with it as its more safe less chance of unwinding it to much and wacking to much boost up.
the one under the bonnit is nearly all the way in an the one in the car only needs one turn for just over 20psi at the min?
iv explaned this as easy as i can.
