Results 1 to 32 of 32
    burton on trent
    fitting a front mount with standard bumper
    I know this topics been covered before but basically im looking at a forge front mount with pipework however i want to know if it will fit with my standard bumper, i dont want to cut gaping holes etc , i need it to look like it grew there.
    Non-member 5alldaway's Avatar
    burton
    Re: fitting a front mount with standard bumper
    have a look on forges website panty sniffer!
    Non-member Adam L's Avatar
    Feb 2003
    SW London
    Have you seen the fitting instructions for the Forge front mount on the 5? Unprofessional comes to mind. Not to mention Forge make pretty **** qaulity parts. Intercooler cores don't cool sufficiently and their actuators are pretty piss poor too.
    burton
    Quote Originally Posted by Adam L View Post
    hey calm down there love, i have forge parts on my car, cant complain
    Non-member Big Supes's Avatar
    Southampton
    Well that's put me off buying their alloy radiator.
    Feb 2003
    SW London
    Put it this way... Their actuators are detachable, to replace the **** diaphrams they use, says alot really.
    Forge and Collins are the only actuators i've seen leak when I test them, this is next to 20+ year old standard Renault 5 actuators, which still hold their pressure.
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    indeed, show me a serious racer that uses either of those pieces of junk
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    I'd rate them in the same league as Pace Products; ie,
    International Area Rep
    Jul 2009
    Hungary
    I have fitted the Megane 2 Turbo IC behind the grill. It was not easy but cools well and the car has its original look. Do not have to modify the original bumper.
    May 1996
    Pie & mash shop
    Hmm, might not be so good for radiator efficiency though...
    Jul 2009
    Hungary
    I have the radiator from a R5 Diesel. It is 8cm wider. Cools perfectly.
    Non-member Spooky's Avatar
    Sep 2001
    SW PMT HQ
    I've got forge fmic on my car. Pile of **** is an understatement.
    Air charge temps are poor on boost and cooling recovery is ****e.
    I've squeezed an intercooler behind the oe grill and run an oe gtt rad and have no problrms with coolant cooling although oil goes through an oil cooler.
    http://emob252.photobucket.com/album...ntercooler.jpg
    chris ska fidos got a raider has got this to fit behind oe bumper although the oe bumper rear had to have a little skim to fit
    http://emob252.photobucket.com/album...R5/Mounted.jpg
    http://emob252.photobucket.com/album.../Photo0112.jpg
    burton
    Quote Originally Posted by Jimmy_GTT View Post
    like the look of this one
    May 1996
    Pie & mash shop
    On track?
    Jul 2009
    Hungary
    On track?
    Haven't tried yet on track. Only a bit hill climbing in the summer (30 degrees). But it was perfect. (it was never so good before)
    The surface is 25% bigger than the std. (thickness is the same) And it was not too expensive.
    burton on trent
    ive actually just sold a megane intercooler on ebay like 2 days ago, hmm ill manage to get it to fit i think.
    Jul 2009
    Hungary
    If you would try to fit it I can help you.
    It is not easy. You need a 1cm shorter belt. Have to cut from the actuator upper holder, have to modify a bit the driver side bonnet holder....
    Campus pulley and belt matey :wink: I run a similar run to you and use the campus parts
    burton on trent
    its cool, ive actually already sold that intercooler
    Non-member BlueFish5Gt's Avatar
    Greece
    How aboyt this one?Is it efficient enough?
    http://www.proalloy.co.uk/cgi-bin/si...35&id=proalloy
    Dec 2004
    Aylesbury
    Quote Originally Posted by BlueFish5Gt View Post
    Places the rad way to close to the engine for my liking
    Nov 2009
    fixing the 5
    mine has a forge fmic, seems ok but dont have an inlet temp gauge to tell how effcient it is, am also going to remove some of the cross member so its sits further in and i can run a standard bumper
    http://www.renault5gtturbo.com/forum...php?f=2&t=6039
    Nov 2009
    fixing the 5
    didnt know they did an r5 diesel? where did you get the rad from?
    Jul 2009
    Hungary
    Quote Originally Posted by baby blue 5 View Post
    Here in Hungary nearly all the bigger auto parts shops sells them. I have bought a nissens one. It was about 80-90£ new. But it doesn't have an oil cooler in it.
    Non-member TrixNFlix's Avatar
    Preston
    Is this the diesel rad your talking about? anyone know if this fits ok?
    http://www.radiatorshop.net/store.ph...on=show_detail
    Jul 2009
    Hungary
    Exactly.
    You have to lengthen the upper radiator water hose.
    And it won't fit with a std. intercooler.
    Preston
    Cheers Jimmy.
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    ive tried both the extra van 1.9d rad and the clio 1.9d rad, the clio one is smaller that the extra van one. they both cool ok but you have to do abit of chopping and triming of bits to get them to fit snug.
    regarding the intercooler, mine is pretty big you can see here it CAN be angled to fit behind the front bumper, i just couldnt be bothered messing around to much so i chopped the bumper[abit too much] but hey.
    Jul 2009
    Hungary
    The R5 1.6D rad is different as I know.
    As I remember it fits perfectly. No modification needed for the fitting.
    North East Regional Rep HULK's Avatar
    Aug 2009
    harrogate, North Yorkshire
    Has anyone ever fitted gt tunings fmic and still used the standard front bumper with some cutting etc???
    Jim
    Quote Originally Posted by 5alldaway View Post
    mmm not sure on the pressure drop across those coolers. Again its a factory cooler designed for 8-10 psi. Got rid of by the 225 crew in favour of a (dare i say it) forge unit.
