Results 1 to 8 of 8
    Non-member 5teve L's Avatar
    RH12
    Is an oil leak...
    ...an MOT fail ??
    Cheers
    Steve
    Non-member Spooky's Avatar
    Sep 2001
    SW PMT HQ
    Re: Is an oil leak...
    I wouldn't think so unless it's causing contamination of somekind that affects it from being road legal.
    Scotland Regional Rep youngscottie's Avatar
    stirling
    yes
    cant remember off the top of my head but the rules sumit like
    when wiped clean the fluid is not allowded to run oevr 25mm in a minute
    or its a failure
    thats on trucks mind but would have thought cars were the same
    Sep 2001
    SW PMT HQ
    My mot guy just said to me you will fail if something is leaking excessively otherwise no.
    Non-member GTphil's Avatar
    I would just use common sense,
    if the sump plug is just dripping a bit it shouldn't be an issue if it's pissing out or contaminating something like the brakes e.t.c as has been said above then it would fail.
    I took my gt for an mot once and the crankshaft oil seal was pissing oil out but the car failed on the fact it had sprayed all over the brake disc, so i went to the jet wash round the corner gave it a good old clean went back to the mot station and got a ticket even tho the oil was still leaking.
    ...an MOT fail ??
    Cheers
    Steve
    Are you talking about the Tomcat matey should be fine, my 5 had it's MOT @ KGC in the summer with a leaking gearbox, would leave a small puddle if left for sometime. They Didn't even mention it.
    I am sure it will be fine,
    RH12
    Yeah but mine drips on the exhaust after a while & smokes a little .. Actually, it may only be after a hard drive though as on short journeys recently it's been fine, I know it drops some though as I see a patch on the road after parking.
    Just need to get it through without fixing it as the rain is a PITA at the mo..
    I think I'll ask my MOT man tomorrow
    Non-member dave r5's Avatar
    Aug 2009
    pitsea essex
    if its a fuel or brke fluid leak then its a fail.
    as said be fore if after 1 minute it spreads acros a sertain area its a fail
    an also if its contaninating breaks
    slight seepage from powerer steering is an advisory
    thats about it realy
