Results 1 to 10 of 10
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Fuel Injector Suppliers?
    Hi, I need a bigger set of injectors, they need to be High impedance approx 550cc... Who is the best company to go to for something like this? Does anyone get trade prices on these type of parts?
    Cheers Ashy
    Non-member Adam L's Avatar
    Feb 2003
    SW London
    Re: Fuel Injector Suppliers?
    A good point, I could do with some side feed high impendence 800cc injectors
    They're cheap from the U.S or Japan mind, even with taxes.
    Salford (manchester)
    Have a look at some evo ones on ebay? there High and do a 550cc i think???
    If no rush wait till feb when im busy on dyno and i mite have some 750 RCs up for grabs, im close to max now.. i need 1000s soons on our D...
    Feb 2003
    SW London
    I started to max out on 740's on my Pulsar at 1.7 bar. I was planning on 1.8 or more but i'm guessing you're running a different fuel rail. I'm keeping all my intake side stock Nissan.
    Feb 2003
    SW London
    [quote=Rob@Backyardracing;118225]Have a look at some evo ones on ebay? there High and do a 550cc i think???
    The Evo's are 550cc in some of the later models.
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Early Evo models are 510cc. From the 5 onwards, 560's are fitted.
    And they're low impedance.
    Non-member SP33DY's Avatar
    Mar 2009
    North East
    Ashy these are the ones fitted to mine, you might have to modify your rail though as theyre longer than stock ones.
    http://www.intengineering.com/VW/18T...-p3471089.html
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Quote Originally Posted by SP33DY View Post
    I'm using a volvo fuel rail marrow as I don't use std pico injectors. Wonder if you can buy then in the UK?
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Quote Originally Posted by Rob@Backyardracing View Post
    Thanks Rob let me know and If i'm not sorted by then I might take them off you
    Non-member steveR5GTT's Avatar
    Mar 2009
    bristol
    Quote Originally Posted by Ashy View Post
    Cheers Ashy
    Seems ur in the same situation as me fella, ive spoke to scoff and he recomends siemens injectors as they work really well with our lumps, heard this off a couple of other people aswell buddy, let me know if you come across a good supplier and ill do the same mate
