Page 1 of 6 123456 LastLast
Results 1 to 50 of 282
    Dec 2004
    Aylesbury
    My red 5
    As i never brought it to Nat day i thought i'd start a thread to on the Volvo conversion i'm doing, i'll update it every now and then when more is completed
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    Re: My red 5
    oh flippin heck thats discraceful! its more porn for me eyes
    Dec 2004
    Aylesbury
    Re: My red 5
    Never thought my car would get you that excited
    Feb 2001
    Rohtang pass
    Re: My red 5
    oh man yo just dont know! thing is ive wanted a b18ft powered 5 for ages but never had the time to do one, so you can understand why i get a boner when i see yours
    the only other one i get to see personally is the rear engined one which has been off the road ever since notnormal sold it, its been rebuilt now but unsure how far its actually got.
    im assuming youve got a that wild cam fitted? did you have the exhaust manifold fabricated or did you buy it from prima?
    Dec 2004
    Aylesbury
    Re: My red 5
    Yeah the wild cam is i the head now and is all torqued down now to the block. At the moment its a prima exhaust ma nifold but its getting taking off and a new one fitted, i've got a few probs with it so need to fabricate a new one. Plus i don't like the Prima one anyway
    Feb 2001
    Rohtang pass
    Re: My red 5
    what issues are you having with the prima one? clearance or something else? i thought with being similar to the gtt one it would be ok! it looks ok from the pics.
    Dec 2004
    Aylesbury
    Re: My red 5
    The quality and the fit isn't brilliant, its been extended already to move the turbo out abit more but i need it out further as the compressor housing is about 1" from the thermostat housing so can't fit a hose on. Also i got to fit the external wastegate in there too
    Its going to be easier to fabricate a new one rather then mod this one plus i can position the turbo where i want.
    Feb 2001
    Rohtang pass
    Re: My red 5
    so will you be going for a shorter manifold to turbo run.? hang on..isnt the OE manifold short.? suppose the problem with the turbo being down the back of the engine would be clearance? and more faffin around?
    Dec 2004
    Aylesbury
    Re: My red 5
    Yeah with the turbo i'm using the space down the back is limited so positioning it above the gearbox works better for me, obviously the run will be longer than standard.
    Just to compare Haz said he didn't feel any difference between the standard manifold and the Prima one, just made getting to the turbo easier, with the new manofold i'll se if i can squeeze abit more out of it by changing the design abit.
    Mar 2004
    Salford (manchester)
    Re: My red 5
    Cooler alert Looks good, awsome..... You going for a mani design to the one said in PM a while ago?.... The only changed id do is move the battery to other side to spread the weight more over the front wheels.....
    Classifieds Moderator
    Mar 2004
    Re: My red 5
    looks good is that still the one from many moons ago?
    Dec 2004
    Aylesbury
    Re: My red 5
    Yeah the cooler is abit big isn't it I'm thinking of that manifold mate just working out where the best place for the turbo is first before i build or mod one.
    On;y reason battery is in that place is because header tank other parts will be living on the other side so hopefully the weight will be even, if not it'll go just behind the passenger seat.
    Dec 2004
    Aylesbury
    Re: My red 5
    Its still the same red one i had when i met you boys in the pub near windsor, if your thinking of the blue one that was sold over a year ago now.
    Non-member scratcher's Avatar
    Milton Keynes - ish
    Re: My red 5
    mate, that intercooler is bigger than my house!!
    its looking good, i didn't get to see it properly in your garage.
    Non-member Gttnutter's Avatar
    Oct 2005
    Amersham
    Re: My red 5
    yep defo looks the lick in the flesh and attention to detail in the bay so far gets my vote
    mark my 5 will be ready on friday so i'll be able to give you a hand over the weekend
    Member D4WNO's Avatar
    Jul 2004
    London
    Re: My red 5
    I think that's the biggest I/C I've ever seen and I have friends into highly tuned Jap cars, damn boy!
    Dec 2004
    Aylesbury
    Re: My red 5
    Quote Originally Posted by D4WNO View Post
    Alot of peeps mention the size of the intercooler, it was ment for a jap car though
    Thing is i'm not the only one with this size intercooler on my car, i believe another high powered car runs the same one.
    Trader paul b's Avatar
    Jul 2002
    Re: My red 5
    its not the size of the cooler, its the way you push it through it......LOL
    Dec 2004
    Aylesbury
    Re: My red 5
    Oh i haven't forgot about that mate I am fabricating a few little panels to direct air into the rad too just to make sure it has enough air flow sitting behind it.
    cambs
    Re: My red 5
    would nt that massive intercooler increase turbo lag?
    Feb 2001
    Rohtang pass
    Re: My red 5
    Quote Originally Posted by mad manz View Post
    im sure a little extra boooooshhht will compensate for that
    Dec 2004
    Aylesbury
    Re: My red 5
    Really depends on turbo, air flow and pipe run.
    I've used this intercooler with a C1J in situ with a VNT and between this intercooler and the old intercooler i had (forge front mount) i had no decrease in boost pressure across the set up.
    Non-member Bodell's Avatar
    North London
    Re: My red 5
    I had a little sneak preview when you done the work on my 5.
    Very nice mark. Should be a minter when done.
    Dec 2004
    Aylesbury
    Re: My red 5
    Quote Originally Posted by Bodell View Post
    Cheers mate, i should be doing some more work on it soon so will have some more pics to put up.
    Dec 2004
    Aylesbury
    Re: My red 5
    Been a while since i added to my thread so i thought i'd write an up date.
    Since last time half the boost hose's have been fitted, alternator is finally on with the new bracket, sourced a coil pack to convert it from the originl dizzy (just got to mount it), fitted the Willies wheels, new suspension all round and i've finally desided on the turbo position in the engine bay. Once its mounted i can finish off the other side of the boost pipes.
    Over christmas the plan is to get the exhaust manifold built so i can mount the turbo and start the exhaust, mount the oil cooler and run the pipes, mount coil pack and modify various other brackets to allow me to fit various bits. Might do abit of wiring too while i've got it out the garage.
    I'll stick some progress pics up soon, its taking a while to do but it'll be worth it when its finished
    Feb 2001
    Rohtang pass
    Re: My red 5
    so where have you decided to mount the turbo unit mark.?
    Dec 2004
    Aylesbury
    Re: My red 5
    Its abit hard to describe but it'll be 90deg the other way to where its sitting now, also got a new turbo for it the old T34 has been sold
    Dec 2004
    Aylesbury
    Re: My red 5
    Got a few pic's of the slow progress on the 5.
    Got the exhaust all mounted now, its Haz's old 3" system which i've modded abit to fit it to the car. I've welded a new 45deg end on the tailpipe and slash cut it, welded new mounts on and made a little mount on the back engine mount so the downpipe will have abit more support. The system has a flexible jiont in the so the movement from the engine won't crack the exhaust.
    On thing i might have to change is removing the scilencer, its quite big and sits very close to all the fuel lines so might remove it and just run a straight through pipe.
    Got the Willy wheels fitted too finally, just need abit of a clean
    Hope to get some more done soon.
    Re: My red 5
    That is just complete filth, you filth loving heathin
    Mar 2004
    Re: My red 5
    When do you think the cars ready by? the wheels suit it well
    Dec 2004
    Aylesbury
    Re: My red 5
    I'm so wanting it done for this year mate, like to have it done for summertime. Money has been abit tight recently so trying to save for the last bits has been abit hard, the ECU is one of the main things i need to get.
    Non-member Kenobi's Avatar
    Jul 2006
    Leicestershire
    Re: My red 5
    Thats just a massive FMIC yeah? Is it overkill markey or really needed?
    Dec 2004
    Aylesbury
    Re: My red 5
    Quote Originally Posted by Kenobi View Post
    I prob didn't need to buy one as big as it but it was cheap and has been used on a 5 before. I've used and tested i before on my old engine and it worked perfect, i wouldn't use it with a small turbo though.
    Feb 2001
    Rohtang pass
    Re: My red 5
    thats coming along nicely
    cant wait to see this finished mark.
    Dec 2004
    Aylesbury
    Re: My red 5
    Well after a long while i finally got an exhaust manifold on my car now
    Thanks goes to Big Jim Racing for making the manifold, i was intending to make it myself but just haven't had the time. I'm glad i got him to do it though as it looks bloody brilliant
    Now its on the car with the turbo and external in situ i can get on with the other jobs to finish off the engine bay
    Non-member mike's r5's Avatar
    High Wycombe
    Re: My red 5
    looks awsome m8 hope all goes well.
    Non-member Blick's Avatar
    kidderminster
    Re: My red 5
    nice bit of kit there mark
    Non-member gtmatt's Avatar
    manchester,sale
    Re: My red 5
    nice work mark , love the colour code off the gear box and engine block what did u use ??
    keep it up mate
    Non-member DK DEVELOPMENTS's Avatar
    Nov 2008
    LONDON
    Re: My red 5
    Looking good, looks like its all coming together for the summer
    Non-member ollie91's Avatar
    Gloucester
    Re: My red 5
    On the turbo where do you get that mesh from so you do not need a filter?? Car is fecking awesome good work fella.
  41. #41
    Dec 2004
    Aylesbury
    Re: My red 5
    Quote Originally Posted by ollie91 View Post
    Cheers mate, its been a long build but nearly there.
    Its not mesh mate, its just a cover that the turbo arrives with to protect the blades.
  42. #42
    Non-member markey b's Avatar
    Bury St Edmunds
    Re: My red 5
    what w/g is that? looks the same as my one from demonmotorsport
  43. #43
    Member Tim B's Avatar
    Aylesbury
    Re: My red 5
    Looks good Mark . How long until you think you will finish it ?
  44. #44
    Dec 2004
    Aylesbury
    Re: My red 5
    Quote Originally Posted by Tim B View Post
    I really want to get it done asap mate but its just money at the moment, need to save abit more to get the thing finished.
  45. #45
    Aylesbury
    Re: My red 5
    Always the way mate never enough money. By the way just to let you know ive stripped all the bits off the van engine, ready to take the head off. Probably this weekend
  46. #46
    Dec 2004
    Aylesbury
    Re: My red 5
    Its a D Developments external, 38mm. Got it a while ago so can't remember the price exactly
  47. #47
    Dec 2004
    Aylesbury
    Re: My red 5
    Ah cool, let us know what you find when you pull it off mate
  48. #48
    Non-member TURBO'D CLIO's Avatar
    Apr 2009
    devon
    Re: My red 5
    That is insane mate, I'm putting a volvo lump in my clio but nothing like as mad as what your are doing...
    What have you changed engine wise then, better pistons ? just looking at the size of that turbo it's gonna be running some serious hp and was curious to what you have changed internally...
    Also what did you paint the engine with ?
  49. #49
    Dec 2004
    Aylesbury
    Re: My red 5
    Quote Originally Posted by TURBO'D CLIO View Post
    Yeah it is going to be abit insane mate, i've done a far bit to the engine and plan to see how much power you can push out of one.
    Bottom end wise its fairly standard apart from a balanced crank and a very light flywheel, top end the head has recieved a far bit of porting, bigger valves, stronger valve springs, custom spec cam which Scoff kindly come up and just a few other little bits.
    I painted the engine block in Hammerite, need a few other bits doing soon but not sure to paint or ploish yet
  50. #50
    Non-member Adam L's Avatar
    Feb 2003
    SW London
    Re: My red 5
    Shame it won't be ready for the end of the month really, Mark.
