got my car up and running again.
still got a few problems to sort out though.
first new clutch pedal as it wont engage gears properly as the bite is right on the floor. the self adjuster must be buggered. as i was snapping quite a few cables before the new engine and clutch.
ive noticed a slight petrol leak underneath the car as its dripping from one of the joints.
what mm pipe should i be using? as currently there is 8mm i.d b&q copper piping joint by rubber piping where it needs to be.
is this the right diameter?
also if there was a leak would this effect fuel pressure in the system? and if so i take it this could effect the safe running of my engine? (pinking etc?)
ive been having probs with the standard water temp gauge. is there any tips any tricks to get this working again does anybody no?
also its a new temp sensor on the waterpump. and im not sure but i think the gauge didnt even flicker when i joined the 2 wires going to it together.
sorry about the essay. just want to get the car running healthfully so i can actually try and keep it on the road this time.
any help much appreciated guys cheers
