I can relate to what you are feeling bro.....................I bought mine about ten weeks ago and got ten minutes use out of it before it all went tits up!.......not a good start at all.
Since then the only use its had was being towed to my mates garage where we fitted a new engine.............
Easy peasy, except it wouldn't tickover properly.....cured thet by fitting the carb off my old engine......then noticed a leak........would you believe that someone had sabotaged the engine we fitted by knocking a phillips screwdriver through the underside of the water cooling pipe on the turbo......(Ever tried getting the banjo bolt off the turbo?.........it's a fu*king doozy let me tell you..........
Sort that out eventually and then discover that the sump on the new engine aint the same as the one on my old one and theres nowhere to connect the breather......so it's sump off time.......except the damn sump won't come off without hoisting the engine up to get clearance!.....
Add to that not being able to get the right clutch cable (what the hell went off with the clutch cable on these evil little cars???????.........when I got one that fitted properly, ie wasn't six or seven inches too long, you kind of notice that they run along the exhaust.....which gets a bit hot, and I guess, snaps/stretches the cable......masterpiece of design there......almost as good as the anti perc fan, which, now I've got it working, sounds like a duck!
I keep having dreams about a cigarette lighter and my car..............
My mate has gone from wanting one to bad mouthing it every time we try and make a bit of progress with it.......I don't think in my heart of hearts that the ruddy thing will ever be right again.....I love to tinker and mess with cars, always have, but working on GTT's is a proper ball ache
Nothing, absolutely nothing is easy........
But its got to the stage now where the little git aint going to beat me!.........no way!
Your car looks superb mate, don't break it up............
Buy mine!..............
just kidding!
Keep the faith, I wouldn't know, but they must be brilliant cars to drive, otherwise why would so many put up with so much grief to keep them running?
Ask me again in six months time and I might even have had a drive in mine by then!.................but hell, I aint holdin' my breath!!!!
