Results 1 to 3 of 3
    Leeds
    AFR mounting boss
    What would happen if the mounting boss for the AFR gauge was mounted after the bend in the downpipe?? would it not be accurate at all?
    Re: AFR mounting boss
    Wont matter really unless you got holes in your exhaust which might cause a problem, as a lot of people make up brackets to put it at the end of the exhaust as well.
    Leeds
    ok, thanks mate
