Results 1 to 19 of 19
    Non-member dave r5's Avatar
    Aug 2009
    pitsea essex
    arp head studs
    has any 1 used these on a c1j of the b18ft
    im in the process of trying to locate sum.
    just wondered what yr veiws were on these
    Non-member boostjunky's Avatar
    Nov 2008
    London
    Re: arp head studs
    Good. They are actually cost effective in the long run if you dismantle your engine a lot because you don't need to replace them during re-assembly as with stretch bolts. Also makes it a lot easier to locate the head gasket/head onto the block correctly.
    Aug 2009
    pitsea essex
    Re: arp head studs
    yeah ive used them be 4 on a pulser build,
    also a d-16, sr20, rb20, rb25 rb26
    just wondered if any 1 has used them on a renault as im finding it hard to locate them.
    Non-member r5 rich's Avatar
    Romford, Essex
    Re: arp head studs
    try speaking to colin as he maybe able to help you out with some contacts mate
    Trader
    GT Turbo Spares co.uk
    South East Regional Rep
    phase i 16 v turbo's Avatar
    Jan 2001
    Morden
    Re: arp head studs
    Quote Originally Posted by boostjunky View Post
    I use ARP head bolts on my Cosworths (YB), they only recommend re using them 3 times.
    Aug 2009
    pitsea essex
    Re: arp head studs
    what collin mate
    collin at at speed with the pug
    buy the way have u seen that thing go. **** its quick
    Romford, Essex
    Re: arp head studs
    Quote Originally Posted by dave r5 View Post
    what collin mate
    Yeah as I am sure he is using all the original internals just with uprated bolts
    Not seen it in a little while but I liked the way he kept it all standard and now its gone track slack stripped which I am not to sure about. I know hes done his turbo in, I am trying to get the 5 down to his one day on the rollers to see what its pushing
    Aug 2009
    pitsea essex
    Re: arp head studs
    yeah apparently he blew the turbo up.
    363 horses tho from a 106
    his cages is awsome. and he has a fetish now with carbon lol
    Non-member markey b's Avatar
    Bury St Edmunds
    Re: arp head studs
    put studs on a c1j and watch it lift up the liners when you take the head off... bad times!
    Aug 2009
    pitsea essex
    Re: arp head studs
    agree with that marky b, thats a good point,
    the ovlov engine dont use wet liners tho. so were can i get sum arp's from
    im stumped no 1 lists them
    Re: arp head studs
    You could try www.anixter.com who are in Derby
    01246 459284
    Mar 2004
    Salford (manchester)
    Re: arp head studs
    I didnt think there was anything wrong with just using the traditional 12.9s, alot cheaper and no issues.. Nothing wrong with ARPs but i just couldnt fork out the cost knowing that the uprated 12.9s cost fook all and work well on these motors... i considered ARPs on the d motor last winter but same again thought sod it, ill re use the 16 year old (prob stretched) head bolts and it never gave me issues... But hay thats why we called Backyard racing, we dont spend money for the fun of it, we like to do things on the cheap
    Re: arp head studs
    The most you can torque the 12.9's to is maybe 70ft lbs before some of them snap.
    The studs, if they're like the ones used on Cossies, can take more. Maybe 100ft lbs. That might be useful if you're making 550bhp from your 2 litre. Or 360bhp from your 1.4 litre.
    Mar 2004
    Re: arp head studs
    I agree with what your saying ian but has anyone lifted a head on a GT yet etc i cant comment on a cossi, but i can say ive fitted them to my 3L 944 turbo project ive done which is still sat under a sheet ..
    I just didnt feel a GT turbo would need them as much? I mean my 1.6 civic making a bull**** figure of 399Wheel bhp but has run 132mph traps hasnt had any probs with head bolt issues... ok if i had the cash id buy everything a could wouldnt we all...
    I just havnt seen evidence yet that a c1j needs ARP conversion...
    Non-member Stuart Clark's Avatar
    Bridlington
    Re: arp head studs
    I use the 12.9's torqued to 100lb ft but i find that the socket moves in the head before the actual bolt distorts
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: arp head studs
    you need to be making an awfull lot of power before you need to worry about head bolts. If stuart can run 12.9's with no problem, as well as the rest of us then there is the answer.
    Aug 2009
    pitsea essex
    Re: arp head studs
    thanks for the disscusion boys,
    i will agree with everything uve all said
    lol @ rob i too mate like to do thing cheap. have used a head gasket twice on 1.5 bar with secondhand bolts and it worked great.
    i am considering arps on my volvo engine, just for the fact that it will be coming apart a lot.
    i will check out that website ian
    Re: arp head studs
    Quote Originally Posted by Stuart Clark View Post
    They must be a better quality bolt?
    Re: arp head studs
    I've not looked at that website, I just phoned them. I bought sixty 12.9's from them by mail order a few years ago. I phoned them last week to ask about the price of some more for the RTOC shop. Seemed like a good price for bolts to some kind of British Standard. But so were the last ones I bought from them and some of those snapped.
    I asked them to supply Unbrako but they don't stock that make. To get them in for me was very much more expensive, partly due to the £12 carriage to them and then another £12 carriage to me.
    For the cheap bolts, if I bought 200, it worked out to be £2.78 for 10. For 200 Unbrako it worked out to be £6.10 for 10.
