what is the best induction filter to use
APEXI/HKS MUSHROOM/itg/ guess the biggest factor i've found with the r5 is its location to the engine, and its ability to get cold air to it as apposed to heat soak from the engine/turbo
have seen mutil[le people on hear move things about to get a better position for there filter
... So that'll be the standard set-up FTW then....
theres naffallfukdidlydoowillydribble wrong with the std airbox setup
if you fancy doing away with the oe setup then most folks also relocate the header tank to free up that area for the filter.
good filters id say as mentioned above, and also blitz look rather spanking.
