Results 1 to 4 of 4
    Non-member gtmatt's Avatar
    manchester,sale
    clio v6 phase 1
    any 1 know how to remove the gear knob of a clio v6 phase 1 thanks matt
    Non-member JRP's Avatar
    Nov 2001
    Hogwarts
    Re: clio v6 phase 1
    They do twist off, but not on a thread. Its more a method to ease removal.
    The gearknob has a plastic sleeved insert that fits into the gear knob, this is then pushed down on to the metal toothed shaft. The teeth create the grip and hold the gear knob in place.
    It is a very tight fit and requires a lot of effort to fit and remove.
    Problem is that the plastic sleeved inserts aren't reuseable so beware when you buy a new or second hand gear knob and make sure the insert is included and unused.
    removed from the thread on the owners site...
    manchester,sale
    Re: clio v6 phase 1
    thanks will screw the hell out of then at work
    Non-member dickiegtt's Avatar
    Re: clio v6 phase 1
    I would be well worried about damaging something i.e the gearstick or box. Would the stick and box not be phased by this and is there not a tool or something else to help removal or am i just being soft and should just shut up and twist like a bitch!
