Results 1 to 9 of 9
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    R19 1.7 Turbo
    just after some info regarding fitting a volvo b18ft engine into a r19.?
    what engine mounts would have to be used? any other valid info if its vastly different than fitting the engine into a gtt.
    just thinking of my next project after i sell the 5[IF i sell the 5]
    not wanting nothing special as i want to do everything on the cheap,car will be
    stripped out and nasty, so just a nippy car with space for me and more importantly my dog, a car that i wont be fussed about getting ditched with muddy paws everywhere or leaving in sh1tty areas.
    although i love them i think a phase1 r19 hatch is upto the job
    dont get me wrong,id love a mint phase1 r19 hatch but i couldnt do it justice as i let my dog jump all over the shop and he'll have it stripped inside before me lol.
    Non-member Ricardo's Avatar
    Re: R19 1.7 Turbo
    Raj, i dropped a C1J engine into a R19 Chamade 16V shell and that went in on the original mounts so theres no reason why the Volvo lump shouldn't fit in without any problems. I assume this as you can drop the Volvo lump in the 5 shell. Maybe fit the GTX bracket on the front engine mount but it shouldn't be too hard. If you're handy with auto electrics then the loom shouldn't be too hard to do
    if you're gonna drop it in a Renault 19 do it in a 16V shell as you'll have better wider track, brakes and suspension already.
    Feb 2001
    Rohtang pass
    Re: R19 1.7 Turbo
    see thats another thing..
    if i get hold of a r19 16v then i may aswell stick with that engine and be done with it as they perform ok do they not??
    if it happens to be a blown engined r19 16v then it'll be worth it i think.
    and electrics..me any good....i think not
    Non-member Schakal's Avatar
    Barry
    Re: R19 1.7 Turbo
    1.7 volvo (renault ) engine is a glorified F type (f2n/f3n ) type
    engine ,so yes it will go straight on to the existing 19 mounts .
    you may have to use renault brackets though as i never seen what volvo
    ones look like .
    1.7 turbo engine is 120bhp standard iirc and you can get it chipped to get up to
    180bhp as i heard on volvo forums in the past (google pruen chip)
    Feb 2001
    Rohtang pass
    Re: R19 1.7 Turbo
    schakal, yes i know the volvo engine is in fact a renault f-series engine, dont know why i didnt think of it like that over thinking i think lol.
    im assuming as the f7p and the b18ft are the same blocks i can simply swap engine mounts if i need to? but with that said there still maybe small mounting differences between the 2 on the block side!
    suppose its just a case of finding a half decent r19 that i can get through an mot, still it wont be happening till i finish my current 5.
    thanks.
    Re: R19 1.7 Turbo
    We had 180bhp and ft/lbs torque in the C1J'd 19, was pretty quick, the novelty of having a 19 that was turbocharged, sounded good
    So much room in the engine bay, we fitted the Megane 225 FMIC
    Feb 2001
    Rohtang pass
    Re: R19 1.7 Turbo
    what does the r19 weigh.?
    ric, surley you did some strippage of the interior/bodywork for the c1j to work nicely.?
    Re: R19 1.7 Turbo
    1060kgs rings a bell, yeah we stripped the carpet out along with the leather interior and the door cards, the leather seats weighed 50kgs. It was on par with a 5 running 15psi
    Feb 2001
    Rohtang pass
    Re: R19 1.7 Turbo
    so obviously abit heavier than a 5.
    ok so could anyone tell me of any volvo breakers that i can source the b18ft engine from in the future.??
