Results 1 to 25 of 25
    Non-member matt1334's Avatar
    staffordshire
    body kit rivets
    hi , im sure i read on here not so long ago someone had brought body kit rivets for the side skirts from vauxhal. Renaults price are stupid and i remember someone saying they were half the price of renault dealers. I have searched but cant find anything..
    thanks matt
    Non-member JRP's Avatar
    Nov 2001
    Hogwarts
    Re: body kit rivets
    when you say rivets you just mean the things you use with a rivet gun.. in that case halfords ones will do the trick.
    If you mean the clips that sit on the sills ask cgb bob as for the side skirt repair kit.
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    Re: body kit rivets
    do you need a specific type of rivet gun for these rivets just that ive got a gun with a few attachments but there all too small for the side skirt rivets.
    also, do halfords sell these rivets seperatly?[without the gun]
    what size are these rivets?
    Nov 2001
    Hogwarts
    Re: body kit rivets
    id have to look in my stores... but yes they do sell them seperate. They work ive used them a few times.
    Feb 2001
    Rohtang pass
    Re: body kit rivets
    kool, can you check and get to me?
    Non-member mr bean aka pete's Avatar
    Jun 2006
    oxfordshire
    Re: body kit rivets
    the body kit rivets are specific to the body kit and have a raised peg attached to the rivet so no anyold rivet will do im afraid i think i read somewhere about vauxhall doing the same clips at a cheaper price
    Administrator dave-sbs's Avatar
    carlisle
    Re: body kit rivets
    these are'nt normal rivets.
    when rivetted into the sill, they leave a few mm sticking out for the side skirt clip to hook onto
    Nov 2001
    Hogwarts
    Re: body kit rivets
    i dont get it... aint a rivet just a riet.. pops into a gun and bang its done... i stand corrected.. but explain a bit more please
    carlisle
    Re: body kit rivets
    it rivets in the same way but it has a collar that tightens against the sill, that fixes itself and makes it solid.
    then there is an extra few mm that stick out, that the side skirt clips slot into
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    Re: body kit rivets
    yes mate but a normal rivet, say a mush head will leave a mushroom head on the sill, likewise a csk rivet will sit flush with the sill, the skirt clips cannot be attached to these
    The side skirt rivets have an extra "tit" on the head so that once the rivet is rivited, you have something for the side skirt clip to "clip" onto
    Hard to explain
    Nov 2001
    Hogwarts
    Re: body kit rivets
    Quote Originally Posted by dave-sbs View Post
    off to renault i go then my normal rivets worked before...but i dont fancy side skirt on the tarmac
    Apr 2006
    Swindon
    Re: body kit rivets
    Dave`s explained it better
    Jun 2006
    oxfordshire
    Re: body kit rivets
    Apr 2006
    Swindon
    Re: body kit rivets
    trying to find decent side skirts with intact lugs nowadays is a mission ive found ???
    carlisle
    Re: body kit rivets
    worth asking stu thc about the vauxhall items, they are identical...but a fraction of the price...sure renault ask about £30 quid for the set
    Nov 2001
    Hogwarts
    Re: body kit rivets
    pete where are the rivets in that pic i see non just the clips...
    And kris.. cgb does a repair kit, and it works, some bonding agent to glue them on after grinding back the original clip.
    Apr 2006
    Swindon
    Re: body kit rivets
    cheers, yeah ive seen the repair kits, nice to hear they do work..always been abit sceptical about gluing stuff like that
    Nov 2001
    Hogwarts
    Re: body kit rivets
    they work really well
    Re: body kit rivets
    Its the rivets holding the clips on JRP, they hang off the extra "tit" left on the rivet
    Nov 2001
    Hogwarts
    Re: body kit rivets
    ohhh those things 6 each side like welded on things???
    I was talking about the things that hold the bottom of side skirt to sill i rivet them on.... ohhh im lost
    Feb 2001
    Rohtang pass
    Re: body kit rivets
    thats what i was on about too the rivets on the bottom lip on the sideskirts.
    carlisle
    Re: body kit rivets
    ahhh, that was a long way round a short cut ,
    on my proffesional opinion- use normal rivets !
    stevenage
    Re: body kit rivets
    A picture of the rivets that might be helpful. They were about £3 + each I believe.
    But did'nt someone mention that Vauxhall do an equivalent for cheaper?
    Feb 2001
    Rohtang pass
    Re: body kit rivets
    Quote Originally Posted by Purple_rob View Post
    there the buggers im after but £3 each who was it that purchased these from vauxhall.? we need part numbers
    burton on trent
    Re: body kit rivets
    renault charge £46 for 10 as i tried to get them the otehr day. Peugetot 205's have the same rivits for holding the door trim on so maybe give peugeot a call
