Results 1 to 42 of 42
    heathfield
    my cars gonna be fast!!
    just ordered a t28 turbo with ktec t3 actuator hooray!!!
    sure i can blow my engine in no time!! lol
    heathfield
    Re: my cars gonna be fast!!
    just thought will i still get away without a dump valve on around 20 psi?
    Quote Originally Posted by price82 View Post
    You are kidding right
    heathfield
    just pushing my luck?
    dont like dump valves
    never had a huge turbo dont know **** about em lol
    If your going to be running that sort of boost make sure your fueling is adjusted to suit otherwise you will be replacing engine parts fairly soon.
    heathfield
    yeah read up on this site
    re jet carb
    new uprated fuel pump
    alloy intercooler
    do i really have to get a dump valve?
    What cam you got in the engine?
    Non-member 5alldaway's Avatar
    burton
    your car is gonna be laggy!
    heathfield
    standard cam at the moment
    what would u recommend
    might be a bit laggy but should be good when turbo kicks in??????????
    Yeah for 1k revs then change gear. Most people who go for the larger turbo suggest the piper 285 but there are a lot of cams out there to choose from. Might be worth looking at catcams to find one suitable for you. It will help the turbo kick in earlier but still going to be laggy if you running a full T28
    heathfield
    ever changed a cam what is it a couple of hours work?
    Non-member Spooky's Avatar
    Sep 2001
    SW PMT HQ
    standard cam + t28 + 20psi =
    mines usually around this mark...long distance runs 18lbs...around town 20lbs.
    doesnt look like much of a difference but there is when it comes to fuelling
    Non-member Shane P's Avatar
    Jan 2006
    Have you seen where the camshaft is ?
    heathfield
    do you find its quite laggy spooky?
    heathfield
    never looked in a gt turbo engine but do own my own garage so have changed cams before?
    Sep 2001
    SW PMT HQ
    ive got a t28 with .42 cold side & .49 hot side with a -34 actuator.
    mines pretty good. boosts from just under 3krpm and keeps going and going lol
    Valve springs will aslo need changing with the 285 cam get a vernier aswell
    Is that a T25 rear housing then?
    heathfield
    i think i will try it with the standard cam as already buying coilovers too all getting a bit expensive and see how she goes
    only use her for fun so not like i have to drive it on long boring journeys to work or anything
    prob change the cam when ive blown the head gasket lol
    heathfield
    any idea what brake im likely to be at at 20 psi????????????
    depending on rest of spec more than likely around 180-190bhp
    Sep 2001
    SW PMT HQ
    give that man a pie
    heathfield
    nice i was aiming for 180 bhp
    set up will be
    t28 turbo
    standard cam
    uprated fuel pump
    carb re jet
    induction kit
    alloy inter cooler (not front mounted)
    standard gearbox
    standard head gasket
    coilovers
    some ****e dump valve lol
    0-60?????????
    0-60?????????
    Now that depends on loads of factors, how good your tyres are, how good the road surface is, how good your gear changes, what revs does the turbo cut in. You will never know. Standard is 7.2 secs so more than likely faster than that.
    Sep 2001
    SW PMT HQ
    Ricardo had mine dyno'd at 18psi, it made approx 180bhp/lbft I believe.
    Ive modded the carb somewhat since and she feels very quick. I doubt I'm making 200 ponies but I must be close at 20psi.
    Need to do a sqm run or 5......
    heathfield
    lol fair point
    thanks for your help again guys your the best
    Sep 2001
    SW PMT HQ
    Ive done a low 5 on sticky tyres, mid to late 5's on road rubber depending on conditions.
    heathfield
    spooky has urs got any other mods than the list ive got for mine,
    not that i wanna copy or anything but sounds fooking fast!!
    Sep 2001
    SW PMT HQ
    ive got a fmic, probably not the most efficent and a side exit exhaust.
    other than that id say identical lol
    ive had my car for a number of years and its been set up for the way i want it to drive.
    i would suggest doing the mods in stages so you can understand whats happening more.
    fuelling for 18psi is straight forward and everything youve listed is more than man enough for the job
    Sep 2001
    SW PMT HQ
    And if youve seen me drive, you'll understand why my car is fast
    heathfield
    sweet can wait till it arrives
    burton on trent
    not sure if this was pointed out earlier but the cam is in the bottom end.
    heathfield
    push rod engine lol forgot haha
    Tipton
    half a days work.
    half a days work.
    Depends if your changing the springs though as that will take longer.
    burton on trent
    half a days work.
    and i presume sparkie means if you know what your doing
    Non-member dave r5's Avatar
    Aug 2009
    pitsea essex
    i was wondering when sum 1 wud pipe up about the cam change in 3-4 hours
    it took me 2 hours to change mine but thats a sohc
    Non-member LampsR5's Avatar
    Midz
    its all about external wastegate :P
    Non-member Maka's Avatar
    Mansfield
    piper 285, fmic, T28, rejetted Carb, LM-1, side exit exhaust, adjustable TDC, NO DUMP VALVE, 20psi all day every day!
    only time i get lag is if i pull off in third
    Non-member rs250nut's Avatar
    Quote Originally Posted by Maka View Post
    I dont get it when people mention lag with a T28,as you say dont pull away in third. All about keeping it in the power, rev it harder
  41. #41
    Non-member sphinX's Avatar
    Feb 2005
    Telford
    Exactly! Lag my ass! All i get is foot down
  42. #42
    heathfield
    ha ha people just jelus cause mines bigger than theres lol
