Results 1 to 47 of 47
    Non-member Romil Davda's Avatar
    Dec 2011
    What is NEEDED to get car ready for RTUK Festival?
    Thought I would start this thread as I know how useful it can be to get some help and assistance with ND (well RTUK Festival) only a week away. What issues or problems do you have (car related)? What parts do you required (I dont mean bigger turbo either!)? or just need hug?:
    • Romil Davda (Staines): Oil breather set up breathing very heavy. dont think its something I can fix before ND, so will just go on track as it is. Also need to get tracking done but no biggie.
    Just over a week to go
    Re: What is NEEDED to get car ready for RTUK Festival?
    Quote Originally Posted by Romil Davda View Post
    make sure no blocked breather's, Compression test Romil
    Non-member Junglist's Avatar
    Dec 2008
    Chester
    Petrol. Chester.
    Dec 2008
    Chester
    Romil are you gonna rub a sponge over your car
    Dec 2011
    Quote Originally Posted by Dan y View Post
    LOL standard for all big events dude... although she's only gonna get dirty driving up!
    See below mate:
    https://www.rtoc.org/boards/showthread.php?t=33687
    Oh drivers side headlight stopped working too (HID's fitted), getting power to unit but not from unit to bulb! Will revert back to standard.
    Finish fitting the roll cage
    Stop oil leaking from the sump plug
    Quick check over
    A good wash!
    Does strip down engine bay, put all new brackets on, sort out manifold core plug, re-wire dash, get through MOT.
    And not here for Saturday afternoon/sunday this weekend as going to watch F1
    Dec 2011
    Quote Originally Posted by Alex View Post
    Quick check over
    A good wash!
    • If roll cage is a "show cage", you can save some time and pass... but knowing you, if you've started, you've got to finish... Mr OCD!
    • Washer for sump plug?
    Dale - Have fun this weekend... I hear they have tickets available to buy at the gate!
    Oh I will I will be in the drivers lounge courtesy of one of our suppliers
    Non-member JP Racing's Avatar
    Apr 2009
    Ely
    Hmmmmm
    Refit box to engine
    Have exhaust temp bung welded in to manifold
    Refit turbo manifold
    Refit turbo and plumb it all in
    Refit wastegate
    Make and fit new screamer pipe
    Refit injectors and rail and fuel lines
    Refit starter motor
    Refit engine
    Refit rads and pipe work
    Refit chargecooler and pipe work
    Wire it all up and have MOTed
    Wash and done
    Might be other stuff I need to do too lol
    Only problem is I don't have any time to work on the car till after ND so going in my daily ride
    Banned
    Apr 2012
    Volvo (Tow car):
    Steering arms
    New tyres
    Repaired DIM
    Fuego (Track Ho)
    New tyres (not arrived yet)
    New brakes
    Buy fuel....lots and lots of fuel.
    Wash car
    Apply some decals
    A show cage?! wash your mouth out Romil, you know me better than that! The sump plug has a washer but for some reason just likes to drip oil still I'll seal it up
    Nov 2008
    Croydon
    Not much for me.
    Re-build and re-fit front callipers
    Clean / re-grease rear calliper hand brake mech and slide pins (one already done)
    Bleed brakes
    Adjust hand brake
    Re-Ft big rad
    Re-fit charge cooler
    Engine & gear box oil
    Tappets
    Fit new top hat bearings for front suspension
    Mount slicks to cup rims
    Good bloody clean!
    Quick oil change on the megane and ready to go.
    Non-member TNT ANDY's Avatar
    Take all my tools out of Fluffy (weekend work horse) and give her a quick once over.
    Non-member Nick k's Avatar
    Leicester
    Finishing making exhaust downpipe and wrap it,
    replace passenger front wheel bearing
    sort out drive shaft gatter as its sh&t itself
    set up fueling as running low 10 on boost
    finish wiring so all willy gauges work
    Bleed air from brakes and ABS modulator
    pray the SAAB T25 i've just bolted on actually works
    Dec 2011
    FFS! will we have any cars on track?!?!
    Brigsy - No van? Did you get the box sorted?
    TNT Andy - I need a hand putting up my tent
    Andy M - Battery sorted?
    As for the rest, only 1 weekend to go...
    I've been speaking to James5 and we recon I got an issue with the rings . I won't be going on track as if she fooks up on track, it may spoil it for others! I am picking up an engine on Saturday and will try and fit this on Sunday but need an engine crane and a new water pump (plus gaskets). Its a real long shot but I want to get on track. There is too much to do to the other white 5: Change wheels, tracking, petrol tank leaking, fit starter motor, fit carb, fit boost hoses, adjust boost, fit AFR gauge (once removed from other 5), do tappets, fit rear arch (but dont have screws/bolts),
    Classifieds Moderator
    Chuck all my stuff in Jamie's car
    Get in mine
    Roof down
    Fuel stop
    Rock and roll...
    West Midlands Area Rep w35ty's Avatar
    Feb 2009
    Walsall
    Well my cars been dropped at bodyshop just so i need/having done:
    Full respray.
    Pick up wheels from powdercoaters the weekend.
    Make seat mounts for new bucket seat.
    Sort out air intake for fogs at work.
    Pick up engine from marky mark and refit it all.
    Freshen up paint on rollcage.
    Finish other dash and get that and all bits flocked.
    Then what ever other little bobs need sorting/freshening up
    So all in all a full rebuild within a week
    Gonna be tight as! dont think il make to saturday hopefully il be at pod though. (Use the saturday to get all car together and sorted)
    Dec 2008
    Chester
    Get decals fitted.
    Fit New thermostat
    Job done.
    Jul 2003
    Change oil in the cup car
    Fill with fuel
    Thrash liberally
    Non-member car.crash's Avatar
    Aug 2006
    I need to pass my driving test. Fingers crossed and I can be on track then
    Dec 2011
    Quote Originally Posted by car.crash View Post
    I thought you already had a forklift licence!
    that drink driving caught up with you... just keep to the shandy's in future
    Not yet mate. Im not sure how good the box is so might get it rebuilt before fitting.
    Get a big 2ltr plastic bottle catch tank whacked on your gtt... Vent holes in the top like mine
    Aug 2006
    Forklift is not a licence, just a competence test.
    Feb 2012
    Nottingham
    Just about the same state as last year for me HG has a leak as loosing water but still boosting but not spending anymore money onit untill this engine comes out and I will rebuild it and sell it on. Then Volvo lump will go in over winter. So no track action at blyton. But I may give it a shot up pod if it gets that far
    Dec 2011
    That'll do for you.
    Non-member Hammer's Avatar
    Jan 2013
    Not coming to the ND, but for the retro show on the Sunday I just need to get some graphics on the sides
    Romil, just go for it! A couple of years back at Mallory, Tony drove his car there and back (3.5 hours each way) with melted piston AND he did the track day! Just get a big catch tank like Brigsy said and pour the oil back in when it fills up!
    Pussy - what do you think gaffer tape was invented for?
    And btw - I'm the tent guy.
    What time are you up there? I'm looking at getting there for 2'30-3.00
    Fill with fuel
    Thrash liberally
    Dec 2011
    I would but its mostly water that collects! Will fit a larger bottle as advised, if I dont get the other one sorted!
    Andy - I am meeting Stuart/Alex at 2pm @ Enfield. Wont be getting to Blyton before 5/6pm mate. I'll drop you a text when we are close by and you can get the tea ready
    Committee Member
    Social Media
    LeeR5GTT's Avatar
    Eat, Sleep, Boost
    Iv had to repair my king lead for the 2nd time this week... i should really buy a new one
    Non-member Wallace's Avatar
    herts
    change a CV Boot then im good to roll
    Nov 2008
    Croydon
    Battery all sorted mate
    Plan on getting most of the jobs sorted this weekend + got half of next week off work to sort last minute issues too.
    Good luck with your engine mayhem! Should have no problems changing it out in one day
    Non-member scratcher's Avatar
    Milton Keynes - ish
    Wash, clay, single stage polish, gucci wax, petrol.
    That should vet me to pod and back. Haha.
    Non-member StuHERTS's Avatar
    Sep 2012
    sort my nearside brake light out. Think its the brake pedal switch itself.
    Clean, wax, load my gear, petrol
    then
    Non-member Pigsnake's Avatar
    Jul 2009
    Cambridgeshire
    Got to put a silencer on the cup car and cv boot.Hopefully that's it.
    Quote Originally Posted by Pigsnake View Post
    Go Pigsnake!
    Go Pigsnake!
  41. #41
    Dec 2008
    Chester
    You doin blyton too m8? Camping?
  42. #42
    Banned
    Apr 2012
    Oh...go on then...lets sling these on
  43. #43
    Non-member Duncan Grier's Avatar
    Coventry
    Quote Originally Posted by DaveL485 View Post
    NICCCCCEEEEEEEE
    You planning on trying to keep up with me in the corners Dave
    Dam I hope the brakes work this year LOL - more aggressive pads up front and fresh oem rears, roughed up discs, fresh racing fluid FTW
    Just that rad that could not cool enough last year so no point turnign the boost up atm
    Looking forward to seeing your beastie in action Dave
    DG
  44. #44
    Trader paul b's Avatar
    Jul 2002
    Just got to get a good nights sleep and get away from work early....
    then as always, I'll check the tyre pressures after about 50 laps,
  45. #45
    Banned
    Apr 2012
    Quote Originally Posted by Duncan Grier View Post
    NICCCCCEEEEEEEE
    DG
    I'm going to give it some stick, lets put it that way
    I'm sticking to a bar of boost as we're not on race fuel and the temps. Plus its only the second outing in seven years!
  46. #46
    Feb 2012
    Nottingham
    Driveshaft
    Suspension top
    That's it if she blows she blows
    If I can get there my mrs is in hospital she tells me Togo but I don't know what todo for the best (20week pregnant) as you know we miscarried earlier in the year so were worried it happening again..
    I really want to go but something's are more a priority..
    Hope you all enjoy it if I'm not there I will try and get to pod..
    Have fun.
  47. #47
    Non-member andybond's Avatar
    Oct 2009
    Doncaster
    Cheating *******.
    I hope it throws it down all weekend.
    ( it wont , but you are properly cheating )
