3 Attachment(s)
R5 campus 1.1 to 1.4 turbo
Hello,i'm Andy from Romania and i want to present my project. A r5 campus that was born with a lazy 1.1 engine 45bhp,that in time i don't think taht was more than 20 alive :).
Therefore,here are some pictures with my car when i was buying her.
Re: R5 campus 1.1 to 1.4 turbo
interesting, ive never seen an r5 dashboard like that before.:)
5 Attachment(s)
Yes its the lowcost campus level i think :cry:,very hideous dash.Any way i will continue my story.
After i buy the car i start to make some little thinks to the car to look better.New steering wheel ,painting the wheels,tint windows.
5 Attachment(s)
Then i make a big modification by lowering the car.It change the hole car aspect,even if the car exterior was pretty bad.
andy_wpo
I like it. Keep the photos coming.
What a difference lowering the car made on painted black steels, lol. Good job you removed that window tint :scared:
5 Attachment(s)
Yeah,lowering the car is a modification that change the look of the car very much i'n my opinion.
Ok.Next stage is repaint the car and do some body work.
5 Attachment(s)
next ..............
2 Attachment(s)
The finish result and new seat
nice job ,wow that dash is a rear one :), renault always suprise me with things like that
5 Attachment(s)
Hello again.I will continue with my project presentation.
After i paint the car,i was thinking to change the engine,with something stronger.First i was thinking to put a 1.7 r5 engine,but i found a gtt engine complet that has a good price and i was thinking way not.And this is how i begine a titanic work to make everythink to go ok on the car that have a base 1.1 engine,so a lot off thinks i have to change,an a lot of stres with the car that won't work ok.
Here are some pics with the engine when i was buying,cleaning,etc
5 Attachment(s)
picsssss
You leaving the engine standard mate or playing with it abit?
Looks good mate :agree:
2 Attachment(s)
Tnks m8,no the engine for now is standard.Like i say i have a lot of problems with it.Fuel pips,fuel pump i burn 3,overheating i change 3 rads.I change the 1.1 rad,then i buy on form a r11 1.4 engine but still overheating from time to time,an today i mountead a gtt rad.I really HOPE that it will go with this one.One off the reason that i join RTOC was to ask peoaple about trobleshooting.
An still have problems with fueling,car go full throttel 1,2,3 and at the 4 it interrupt and most take the foot from throttel.I think that fuel well was the problem,i buy another one.
Any way i was very happy how the car goes with this engine,even if it not go full throttel.Big diference from 1.1 to turbo
A pics of the car how was looking in the summer
Did you know how the engine ran in the previous car it come out of?
Over heating could be a number of things, thermostat not opening, headgasket, etc.
1 Attachment(s)
The engine was taken from a schrott,so now i don;t now how was running befor.The thermostat was change,but i\m pretty sure that the rad was to small for this engine.
this is r11 rad
3 Attachment(s)
From yesterday,when i mounted the r5 gtt and gauges,because this dash bord doesn't show anything :(.So oil press,water temp,and turometer.The last one i don't no where to connect the wires to work
The car how it looks after 6 months unmoved
F..k :mad: my water is heating again very bad.What you guys think it cold be?What are the symptoms of blow headgasket?And my water gauge not indicating right.My water is heating like hell and the gauge read 40 celsius degrees.The gauge are from autogauge
Just want to check have you bleed the water system up correctly?
Maybe the thrmostat is siezed, worth trying another one or even taking it out and running it up to see if it heats up.
The thrmostat is out.Maybe i don't bleed the water system up correctly?How to do it?
Pleas give my ideeas because i;m desperate,i will burn the car if i can't make her to work :wasntme:
Fill the header thank up, while holding it higher than all the water pipes then undo the bleed nipples one at a time till water flows through them. Once all air is out refit bleed nipples and refit header tank to bracket.
The engine doesn't need to be running to do this.
Markey Mark (BD)
:agree:. Bd goes worldwide....:D
Markey Mark (BD)
Tnks m8 i will tray to see if this is the problem.If not i will change the headgasket to be sure that is not blow.
p.s is normal that water don t come out off pips if i dont lift up the header thank?
Hello again :).I resolve the problem with water heatting,alternator belt was off :ashamed:.Now another question,how i adjust my carburattor to stay idle?
andy_wpo
Clean the idle jet out first of all, big brass screw on the passengers side of the car (for a left hand drive car). Whats the symptoms?
1 Attachment(s)
i thought this pic might help to locate the idle screw :)
Tnks modfather.I have a problem when ii throttel sudden,the engine want to die.maybe the carburetor issue?
andy_wpo
Sounds like accelerator pump issue, have a lookat the articles section to see how to set it up mate
Chris Hebden
Can you give me please a link,i cant find the article.tnks
andy_wpo
click on this link and at the bottom it tells you how to setup the travel on the acc pump
https://www.rtoc.org/boards/showthrea...highlight=carb
modfather
:agree: This bit below
James5
5mm Drill bit against slot beside throttle butterfly, then let throttle butterfly rest against drill bit then adjust the small bolt to ac pump so that the ac pump Is pushed fully in when the drill bit in place.
tnks,but to be onest i don t understand much of what is writing there,Were is ac pump,how it looks?I don t now very much about carbs,so sorry for the inconvenience of you could show me some how it will be very good.
In the pic below its on the left hand part of the carb (which is the base), its just on the right hand side with a nipple sticking out of it for a vac pipe.
https://www.rtoc.org/articles/i/autof...YAKJJCMNZI.jpg
Have a read here mate https://www.rtoc.org/boards/showthread.php?t=4743 should give you some more pointers!
What usually needs to be done as regards the fuel system in a 1.1 to GTT conversion guys? Fuel pump/filter? Fuel pressure regulator?
If so, have these been fitted along with the engine Andy?
Trevhib
When converting a 1.1 to gt you have to fit the gt pump, filter, regulator and the sender unit.
1 Attachment(s)
tnks chris once again :ashamed:.
Trevhib i change all the thinks that MM say.And i change fuel pips because 1.1 fuel pips was to small.
P.S This is acc pump?So what i do?i take it off and putt it again or???
Ok, smart. :agree:
Sounds like you're in the right area with the carb. Make sure you haven't got a boost leak that's opening up under pressure.
1 Attachment(s)
It will be very ok to have a rebuild carb kit.But in my country i can't find anywhere or maybe i dont now from where to buy it. was at renault dealer to ask about it an they say,thay don't bring old parts at order.
And to buy on from cgb or k-tec is more expensive the transport than the kit.So i will wait to make more money and buy more stuff.For now car goes ok,but have some fuel issue.i didn;t replace the fuel pips even that i have them,so at high rpm car hesitate.i belive that is the problem.
Another problem maybe that when i buy the engine,i take out the carb to clean it.The carb looks like new but when i open it i broken this pice.i don;t now how i call it.Can apare problem because of this???
andy_wpo
Yea thats the acc pump! You see that brass coloured flap, put a 5mm drill bit inbetween the side of the carb and the butterfly (the brass coloured flap) and tighten or loosen (what ever it needs) so that the arm that is connected to that threaded bar is pushed all the way in at the carb.
If you have a look at the previous pic i posted that shows the acc pump arm out, when you check yours, with the butterfly open 5mm yours should be the opposite to this and held in place with that 6mm nut.
Tnks RTOC for the sticker,cars member,etc.I'm very happy haveing a rtoc sticker :D.I put a pics when a put the sticker on
4 Attachment(s)
my new wheels.O.z f1 16" :wasntme:
5 Attachment(s)
Some day pics with the whells
Hello again :),after going with the car 2 weeks day by day with no problem,now i have a littel one.One day after i race a littel in town,i see that the oil pressure gauge show me 25psi and some time even 10psi.I check the oil........and :eek: all most not a gram of oil.i take a look under the car and few spots off oil on the ground and a lot leaking from..............i don't now from where.When i go normal its not leaking,and the presure ist ok,when i go a littel fast the presure come down and is leaking from somewhere.
Can you give me some ideea???I must say that is not the sump baffled,because is dry,i suspect that is leaking from up side.
Could be the rocker cover gasket????
4 Attachment(s)
Although,the car sit like this for about 2 months :eek: ,i want to prepare the car for a drag race that will take place,in about.....a year :wasntme:.Is one off the best drag race from my country,like Sant Pod to you.
So i was thinking to make a nice presence and go with a very fast car.I was thinking at about low 13-mid 12 s/400m.And i want to do this with the 1.4 engine,but i want to be reliable,at least how far is posible.
So give my advice how much HP i need and what will be the mods that i have to make for this achivement?????
Nobody?????:confused:,i see views but no suggestion:coffee:
i would start with a larger alloy front mount intercooler, a larger turbo a different cam (piper 285 seems to be the cam of choice) , also correct fueling at carb to go with all new mods :)
ps when i read your posts ,in my head i give you a funny accent even though i have no idea what a romanian accent sounds like :laugh:
:laugh: :laugh: :laugh: :laugh: good one:agree:
What happens with you guys :confused:???Nobody want to help me to make a fast car???A recipe or something????
This days i put a biger intercooler,a bigger exhaust,a bigger radiator,rejet the carb and push at 1 bar the pressure.I earn some hp without the cams????How much pressure i can put on the T2 turbine to be relative ok?1.1 1.2 bars???? What minore tricks i can made to earn more hp????
Im thinking to put a thermal exhaust to heat down the engine compartment.what do you think ?????
16psi (1.1 bar) is about the limit on the standard T2 to work effectively, if you want more power i'd be looking at increasing the size of the compressor wheel and housing.
For the moment and your engine spec i'd say standard cam will work fine and should see some good power from it, if you start to increase the turbo size then i'd start looking at cams.
To be honest your not going to get power from heat wrapping the downpipe, all it'll do is hold the heat in the exhaust.
4 Attachment(s)
tnks markey.Yeah i no i don't gain power from wrapping the downpipe,i do it for decrease the heat from the engine bay.
I now 99% what to do to gain power from an engine,i just ask you guys because i have do it to this engine and now what works and not.
Here are some pics of the new rad setup,the intercooler and how bad the car looks right now :coffee:
