Had my phase 1 on the rollers this morning, thought it would make around 160@flywheel but it made 198bhp with 207 torque at about 19psi at the carb top! Well happy with thatthought it was going well!! Must be this cold weather helping
Impressive what mods you got??
Here's a list of mods
Piper 285 cam
Garrett T25 rollerbearing
2 1/2" downpipe
2 1/4" ktec exhaust
Gt tuning double cap
Fettled carb 1.3main 1mm air corrector 2nd stage drilled out to 1.2
Been getting 11.8 on the Afr at wot seems to be running sweet![]()
Nice work bet she does go well![]()
Here's a small vid of her on the dyno
http://www.youtube.com/watch?v=nJWaybybSZk&sns=em
Good result mate, especially for only 19 psi!
Way, that's a good result. As the others have said, she must be quick![]()
you should be well pleased with that result fella. Nice looking 5 by the way😉
I run r888 and found I hardly get spin now just launch but add a bit of damp road holy bjesus hold on lol
That's a really nice looking phase 1. It's nice to know that you can make 200hp with a side mount ic. I have a massive front mount on the car I just bought and personally don't like it. I want a nice side mount so I can fit a standard bumper on. Good work mate
Thanks mate! It's a Gttuning bread bin I think there probably the best standard position inter cooler you can get although I did suffer a bit of heat soak on the second dyno run! Probably get a bit more air flow on the road though as the fan at the dyno was quite small.
I think side mounts are ok for road use but if your thrashing it round the track a front mount is defiantly better! The cosie cooler behind the grille seems like a good bet!![]()
I shall look into the cossie fmic, it sounds ideal. My huge ktec effort will be for sale shortly
I think there are bigger and better ones than that too Beng. There have been loads of projects on here fitting various FMIC's behind OE bumpers. Difficult to know what to search on to find the pics/advice though.
I do remember Bood's car had a brilliant Cossie FMIC mod:
https://www.rtoc.org/boards/showthrea...t=29689&page=3
I'm thinking about a front mount behind the original bumper nowThen I can put the air filter in place of the old cooler win win
The engine I built, and my old car. Ported head, ported inlet, 25 degree angle on valves and updated h.gasket. Helix paddle clutch also valeo green box cover.![]()
