Morning All,
Having a problem with my evo 6 that is driving me mad and I am desperate for some assistance as I can't seem to sort myself or find and answer or much help on the MLR forum.
I have a small clonk/knock from the front end for the past few month's not been that bad until recently and car now feels dangerous to drive in that when you turn the steering wheel either way it feels like you are going over small bump's (when I am not).
I originally replaced the following over the last 2 months:
Fitted brand new coilovers with solid top mount's,
New drop links
New track rod end's,
Passenger side driveshaft (due to a split gaitor),
RS rear diff setup (non related problem due to AYC pump failure),
I even removed the front transfer box as heard about the 4 bolt lsd's shearing on the MLR forum but that's not a problem for me as mine is an open diff type therefore no 4 bolt's and no movement that shouldn't be everything is within tolerance so that is now back together and I just need to fit it again.
Only thing's left to do are ARB bushes, Lower balljoint's and wishbone rubber's,
I have just got some new poly bush ARB bushes so will fit those when I get a chance
Any thought's
(not a cheap car to work a problem out on everything is expensive)
