Results 1 to 16 of 16
    Feb 2013
    phase 2 1990 r5 gt turbo
    Cant seem to load pictures
    http://www.ebay.co.uk/itm/Renault-5-...item19d8d7f6e5
    1990 Renault 5 Gt Turbo
    80,000 miles
    mot till November
    tax till May
    £2800 Ono
    For sale is my Renault 5 GT Turbo
    I have owned the car since 2009 and used it to commute to work which was a 50 mile round trip.
    I then decided through the winter I would put it in my garage which is where it had stayed until couple months ago.
    New parts fitted.
    Fully reconditioned starter motor (tnc vehicle services)
    Rear brake pads
    Reserve fuel tank strap
    Spark plugs
    HT leads
    Battery
    Oil filter
    Oil
    Fuel filter
    Low temp fan switch
    Fan relay
    Bottom ball joint boot
    Carb stripped down cleaned up and set up using gas anayliser
    Carb has uprated jet and new mixture screw.
    valve clearances adjusted
    Underside is solid all waxed no rust.
    When i bought the car head gasket went. Once removed I sent the head to be skimmed and pressure tested however found out that it had a crack in it.
    So I purchased a new cylinder head,new valves,oil seals and new head gasket set.
    The list.
    Momo steering wheel
    Sparco pedals
    B&M short shift
    In car boost controller (not plumbed in)
    Turbo timer
    Cobra alarm and immobilisers
    Turbo- i don't believe is standard but cant see any info on it
    Turbo technics actuators
    Side exit exhaust
    Forge dump valve
    In car boost gauge (not plumbed in)
    Drilled and vented front discs
    Solid vented rear discs
    Fox 15" alloys
    Good tyres
    Chrome rocker cover
    Chrome lobster
    Rev limiter moudule (can be programmed not sure how)
    K&N air filter
    Ktec rear bumper and side skirts
    Rear boot brace
    Lowered all round on adjustable koni's
    Samco boost pipes
    Scuttle tray
    uprated cam (unsure what make)
    Reconditioned gearbox (previous owner had done)
    Lightened flywheel
    Braded turbo oil feed pipe
    Sub woofer and amp that came when i bought it not currently installed
    service history it has stamped service history up to 60,000 miles also i have a box with loads of paperwork and old mots
    Since owning the car I have done roughly 1000 miles and that was in 2009.
    It had been garaged for a long time until a few months ago when I started to spend my time restoring this very rare car.
    since being restored its covered about 30 miles.
    Location-- Budleigh Salterton, Devon.
    also i have a few spare parts original air box, turbo heat shield and few other bits and bobs.
    If you have any questions or interest please feel free to contact me.
    Feb 2013
    Re: phase 2 1990 r5 gt turbo
    now £2600
    Feb 2013
    Quote Originally Posted by 1iamk View Post
    now £2600
    NOW £2000 no offers or swaps
    Feb 2013
    Aug 2004
    I will offer £1500 cash...
    Genuine offer
    Moderator Red October's Avatar
    Mar 2012
    Stoke on Shizzle
    Is this the one thats been on the bay a few times since xmas? Looks worth a punt imo.
    Feb 2013
    thanks but i cant afford to let it go that cheap
    Feb 2013
    it has been on few times but just seem to get messed around people bid and dont turn up its going through the whole reporting to ebay **** i cant be dealing with. so its not going back on again.
    Mar 2012
    Stoke on Shizzle
    Leave it in classifieds if your not in any rush and it will sell mate im sure someone will get close to your price. Soon as the sun is out so will the wallets haha.
    Aug 2004
    That's fine, as stated a genuine/fast offer...
    Jul 2009
    lost
    dont look a bad lil five. thought it would have sold
    and chris , thought you wasnt buyin anymore fives
    Aug 2004
    Quote Originally Posted by r5_scotty View Post
    I do fancy a Tungy again haha... Nice 5 this, a few changes will make it easy to sell on again and not loose out financially
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Ph1 struts?
    Feb 2013
    Ph1 struts?
    Not to sure!
    Tipton
    Ph1 struts?
    looks like it
    Non-member Benjibrady's Avatar
    Jun 2011
    Bruton
    Is this still for sale?
