i've just changed the boost pipe with the over boost sensor in it and one of the cables was very frayed and broke off. how essential is it that its connected or can i leave the cables off?
cheers
cheers
13psi on the standard guage.
Naaa you'll be mint.
nice one. i'll tape it out of the way
not stealing the link but what psi does the sensor cut in?
ive been told mines running 15psi and it hasnt cut in
the sensor is adjustable
there is a little screw between the two terminals
Im sure it cuts in at the end of the red on the standard gauge on the dash from memory, circa 18psi carb top..
Olly your gtt is running circa 14psi carb top, 3/4 into the red. Overboost didnt cut in after working one was fitted so no bother there
