Results 1 to 17 of 17
    Non-member Schakal's Avatar
    Barry
    best handling car ?
    people use different stuff ,different makes on their cars ,
    konis ,ledas coilovers ,lowering springs etc etc .
    but what in general does make a car handle/corner good in general ??
    i am looking for basic guidelines , i.e : "front lower than rear "
    "using shocks from a heavier car" "using stiffer springs "
    "thicker anti roll bar" "widest the front/rear track the better" etc etc .
    i am hoping this to be a pretty long thread and help most of us
    in the long run .
    DISCUSS
    Non-member BriC's Avatar
    Dec 2005
    Re: best handling car ?
    Camber, tyres and stiffness of the suspension / chassis all play a part (amongst other things). It isn't neccesarily a case of one set up is the perfect setup, as differing surfaces will play a part in how the car handles.
    Trader
    Big Jim Racing
    Chadwell Heath, Essex
    People have written their PHD thesis on single aspects of cars dynamic behaviour. It's a pretty huge subject. If you're into maths, there are some good books.
    Oxfordshire
    Quote Originally Posted by Big Jim Racing View Post
    anybody want to borrow my Milliken and Milliken?
    Kent
    The Clio Williams probably gets the nod over the 205 GTi as the best hot hatch in the handling stakes....so the nearer you get to that set up the better???
    Non-member Ricardo's Avatar
    Quote Originally Posted by Matt5 View Post
    Then how about the Clio 172?
    Barry
    dibs
    walsall
    just buy an evo 6 best ive ever had
    Oxfordshire
    Quote Originally Posted by bye_all_c_ya View Post
    oh yeah, they're really fast
    http://www.youtube.com/watch?v=cdXtIt4xd_Y
    Non-member rs250nut's Avatar
    http://www.youtube.com/watch?v=fTURKAhFBJA
    or the later 1991-1992 Williams FW14B
    Non-member car.crash's Avatar
    Aug 2006
    those newer clio 172-182's seem **** hot in the corners and will mince any 5 imo.
    Even a five with a multi link rear end, magnesium uprights, rose joined bottom arms adjustable top mounts etc etc and three days on the chassis dyno and built on corner weight scales?
    Aug 2006
    was you out cornering the clios on that setup then at mallory?
    Non-member SP33DY's Avatar
    Mar 2009
    North East
    My personal preference is the clio trophy vintage.
    But I am biased
    Member robw's Avatar
    I think your missing the point? There were a number of 5's cornering quickly, each with different set ups and respectively with differing amounts of dosh behind them. What counted on the day was a BALANCED set up. One of my good friends Robw was taking gerrards at fairly similar speeds to me with a very soft set up for the track, (same tyres) but he has a quaife ATB and is an exceptional driver. I am a pussy compared, but have a cup rear beam and massive front ARB with 275lb coilovers and stiff dampers to match. What I thnk you should do is start soft and then invest to a stiffer set up once you can drive what you've already got.
    I'll never forget what Andy Cooke said to me, spend and drive with your head, not with your heart.....
    Albeit down to drivers knowledge of trackdays/Mallory Park, mine overtook the Clio cup 172 and the Pug 306GTI-6 no probs. I use those cars as a comparison as i feel they're closest in all departments in what they offer.
    Modifications:
    Koni yellow suspension with adjustable damping, fronts set up lightly harder than the rear
    Apex springs
    Budget induction kit
    Yokohama Parada Spec 2 tyres
    Interior all in place
    IMO the 172 out the box is a great car for trackdays, the Koni's IMO give you the chance to stiffen up the dampers a little more, i also upgraded the discs to grooved and changed the pads to DS2500 as apparently the OE don't last long on spirited driving. My next job (apart from gearbox ) is fitting the braided hoses
    Non-member Hoolio's Avatar
    Wallingford
    Quote Originally Posted by SP33DY View Post
    But I am biased
    Another Trophy owner? Are you on Cliotrophy.co.uk?
    Interestingly the dampers do almost all the work on the T, very soft springs.
