Results 1 to 28 of 28
    Glasgow
    My engine bay...
    Sorry for all the questions
    I took some pics of my engine bay the other day as a member pm'd me saying my vaccum pipes arnt setup properly and that my carb wont fuel properly on boost ...i pm'd the user back with pictures but im guessing he's busy. I put up a post before about the juddering/hessitance when off boost driving normally ..the car judders a fair bit.
    Im running standard boost and as far is i know standard jets on the carb ..also running a forge FMIC.
    here are the pics -
    I know most of you will be saying "ARGH...WHAT A MESSY BAY!" its all i can work with at the moment ..as id need to see some tidy bays to get some ideas
    Dublin/Ireland
    Re: Does this look ok?
    make sure ur metal boost pipe does'nt contact ur alternator connections!
    Glasgow
    dont worry it doesnt ..i made sure there was plenty of space from them and the ht leads ..so i dont get an arc(sp). My main concern is ...are the pipes all in the right places? ...i dont wanna go driving it hard and its destroying the engine in anyway .. sorry for being paranoid as its my first engine conversion ..i just wanna know if its ok to roll before i go a proper blast
    Oxfordshire
    you need a pic showing where all the pipes on the carb going off to the left side of the first picture go. Also make sure that the pipe stringing off to the AEI can't leak - it looks like you've used windscreen washer hose...
    Glasgow
    LOL at the screen washer hose ...i had a box of pipes given to me with the engine and had to work with pics off my computer ..thats my excuse
    Ill go and take some detailed pictures of my engine for you then ..cheers
    Glasgow
    As promised ...more pics of the engine -
    Hope this helps
    Oxfordshire
    looks reasonable to my untrained eye...
    some comments from me:
    - as mentioned previously, ensure the pipe to AEI can't leak, if it does you will det your engine.
    - consider some kind of heatshield around the brake fluid reservior, the GTT one is mounted remote for a reason.
    - is your turbo elbow blocked? I can't see anything screwed into the back of it.
    Non-member Spooky's Avatar
    Sep 2001
    SW PMT HQ
    Also, fit a thermostat in the top rad hose
    Glasgow
    Yeah turbo elbow is blocked by a wheel stud ..we have just cut the end off.
    Thanks for the advice on my brake resevoir ..ill get something made up for it
    and the aei pipe ..i can sort that no problem ..i have plenty of silicone hose.
    Apart from that ..is it good to go? ..i was told that the vaccum side of my carb aint setup properly by a member on here ..he said my carb wont fuel properly on boost ...this is the reason for this post ....i dont wanna go damaging things .. would this just be my aei pipe?
    Im a newb to this as you can tell
    Edit - there is a thermostat in the top hose
    Sittard, Netherlands
    Nice breather system with the bottle by the way...
    Glasgow
    Quote Originally Posted by jantheeven View Post
    Yeah its getting replaced by a can of stella artois soon ..everytime i drink i forget and crush my can
    By the way... it's probably better to run the water hose that goes from the water pump to the bottom of the header tank underneath the carb boost pipe imo...
    Dec 2004
    Aylesbury
    Apart from a good tidy up () its looks ok to me mate, many cars have been plumbed up like that before.
    Everyone has a different way of doing it, i do it a few ways too depending on actuator used and carb top design.
    Sep 2001
    SW PMT HQ
    You have something missing on ze carb...
    The brass coloured nipple on the passenger side should have a pipe connected to it...
    Glasgow
    haha thanks for the comments people ..i will get them water hoses under the boost pipe next time im working on it
    Probably also a good idea to strip your carb and buy a service kit... this way you can give every little bit a thorough clean and you can also check your jet sizes...
    Sep 2001
    SW PMT HQ
    Quote Originally Posted by Bass J View Post
    where eh ?
    Good one! Fuel goes in there...
    Oxfordshire
    vacuum side looks good, the only bit I can't see for sure is whether the pipe from the fuel pump is into the side of the reg, and the return to the tank is in the bottom.
    silicon vac hose will leak at the joints at around 14psi, always use a tyrap or something to hold it tight.
    you need a second hose clip to hold the stat in place.
    Glasgow
    any pics of where this pipe comes from/goes to ..will be great folks ..and spooky ..there is a thermostat ...its just hard to see by them pics (that smilies class! )
    Oxfordshire
    no it doesn't, you can leave that open. Originally it would have a pipe to the carb top.
    edit, passenger side just has a pipe out to the road, I'm talking about the one on the driver's side (this is the UK, driver sits on the wrong side)
    you're right... I commented too fast without thinking first
    Glasgow
    Ive took a pic of my fuel pressure regulator for andrew cooke with the pipes labelled ...i was advised from rob@backyardracing over msn how to plumb this in.
    Pic here -
    Oxfordshire
    looks good to me
    Glasgow
    good to know haha.
    So am i good after sorting the aei pipe just to get my boost and fuelling setup properly with wideband etc then?
    Sorry for all the questions ...im told its good to be cautios(sp) with these engines before doing anything to them
    Oxfordshire
    functionally you should be there.
    Reliability wise, the rat's nest nature of the installation may give you problems, the biggest risk being fire. Make sure that you're happing with the condition and fitment of the fuel lines, and that they can't rub on stuff. Also check your wiring, that the thick cable to the starter motor, and the alternator can't rub and short out.
    It looks like you have nylocs on the manifold studs, they will melt and come undone. Always remember that the manifold, turbo and manifold can glow red, don't let them melt stuff.
    Beyond that, have fun, and build the boost up in small steps, that way you're likely to spot any problem before you do any real damage.
    Mar 2004
    Salford (manchester)
    Is that a small kink i can see in that aei vac line..........
    Glasgow
    at the carb side..or where ive attatched it to the bulkhead?
    If so im replacing the whole pipe with a silicone pipe ..rather than a random pipe i found in a box
