Results 1 to 18 of 18
    Non-member FurioKid's Avatar
    Lincolnshire
    Anti perc fan
    Just wondering, i've removed my anti perc fan, and as such it can be a pain to start when left for an hour or so after a long run. I didn't bother fitting it cos it used to stay on for upto an hour after switch off, and eventually killed my battery.
    I was wondering though, if i refitted it and put it on a switch to run when driving but switch off when stopped, would it make a difference?
    Apr 2009
    sevenoaks
    Re: Anti perc fan
    no it wouldnt make a diffrence, as its ment to be there to pass cold air over the carb base as the exaust is right underneth,
    Re: Anti perc fan
    The anti perc fan is only there to cool the carb down after a long run just incase you need to start the car straight away, eg at a petrol station. The carb would have cooled down after an hour so you got problems elsewhere. Plus the anti-perc does not run whilst the engine is running.
    Lincolnshire
    Re: Anti perc fan
    K no worries then, if i leave it for an hour it does start after a couple of pumps of the accelerater, but can be a pain in the arse if started before.
    i have heat wrapped my exhaust to try and keep the heat down a bit
    Re: Anti perc fan
    Agree with the man with the BigFoot, mine used to come on about 5-10 mins after turning the car off after a long drive and parking up and it would stay on for about 20mins or so.
    Re: Anti perc fan
    My anti perc does run when the engine is running. What i did while i was waiting for a new switch was run a switch and turn the perc fan on and leave it while everything was switched off, left it for 10-15mins and went back out to switch it off again! A pain if you forget it though
    Non-member ScottGT's Avatar
    Apr 2009
    Dorchester
    Re: Anti perc fan
    Or just learn to live with the rough starts?
    Apr 2009
    sevenoaks
    Re: Anti perc fan
    i have lol
    Lincolnshire
    Re: Anti perc fan
    Quote Originally Posted by R5GTTRaider View Post
    i have lol
    so i ain't the only one not running one lol. Think i will as don't fancy forking out for efi
    cheers for the inputs guys
    Re: Anti perc fan
    It doesnt take much to get them working correctly though
    Apr 2009
    sevenoaks
    Re: Anti perc fan
    my 1st stage is blocked i think, and been told so but the great jrp, so thats kinda half my starting problem also
    Lincolnshire
    Re: Anti perc fan
    Think mines overfuelling, as after a long run, switch off and the exhaust pops, so the carb does need setting up which probably doesn't help
    Non-member markey b's Avatar
    Bury St Edmunds
    Re: Anti perc fan
    i dont have an anti perc, or a choke or even fast idle.... but it still starts ok from hot or cold
    Apr 2009
    sevenoaks
    Re: Anti perc fan
    Quote Originally Posted by FurioKid View Post
    no thats you not letting the turbo cool down, do you let the engine run at idle for 3-5 minutes, cos when i forget and ive had a hard run it does so, but good as it reminds me lol, only forget now now and again if im in hurry
    Apr 2009
    sevenoaks
    Re: Anti perc fan
    you proberly got a clean and working 1st stage and acc pump
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Re: Anti perc fan
    A blocked 1st stage enrichment won't be the cause for bad starting prob's.
    It's fairly normal/common to hear a 'pop' from the exhaust when switching off the engine after a long run.
    Apr 2009
    sevenoaks
    Re: Anti perc fan
    but isnt that pop due to the turbo beeing to hot and not let to cool down
    i only ever get it if i switch straight off, and never if i let it cool down which i do more often than not depending how far ive gone and if ive put my foot down
    Lincolnshire
    Re: Anti perc fan
    Thing is i don't really drive it hard cos i'm still bedding the engine in, but even so i do give it a couple of mins for everything to cool then switch off, but still does it everytime lol
