Page 12 of 19 FirstFirst ... 2345678910111213141516171819 LastLast
Results 551 to 600 of 908
  1. #551
    Re: bringing my 5 back from the dead
    Quote Originally Posted by philr5t View Post
    And then it went BANG at 14psi not pulled it apart yet but I'm guessing head gasket
    Phil, that's such a ****ter matey after such a short amount of time, but VNT + very High comp C1J engine + standard ignition timing doesn't work. Lower that compression and look into mappable ignition matey unless you can afford to go EFI yet.
    I feel for you matey i know the amount of time and money you have spent on the car at least you have had some good times and made some effort's in the car though
  2. #552
    Er i ran a 9 to 1 ratio, standard timing and 20psi on my vnt for two years before i went efi and the only blow ups were my fault and the not the setup.
    What comp ratio, you running fella?
  3. #553
    I think Phil's setup is around 9:1 also and it det's below 14psi.
    My old setup was 8.6:1 and detted over 21psi and ignition timing was fully retarded, I only blew mine up when I moved the ignition back to standard and every time within 5 miles of doing so H/G would go.
  4. #554
    Non-member philr5t's Avatar
    Dec 2008
    tadworth
    I'm running 8.8:1 mate and I'm sure I could here det well before the boost was up to 15 psi afr's were reading around mid 10's to low 11's so well to rich temp gauge was fine and sitting on the first mark on the gauge but after a quick burst up the road it picked up a misfire and was just plooming out White smoke I have a feeling whatever it is it's to do with the cylinder 2nd along from the water pump as I done a comp test a while before and noticed that bore was a lot lower compared to the rest of the cylinders. If it's the h/g I'm not to worried and can probably get it running again the same day but my problem is what has caused this at only a bar of boost has anyone ever had this before ? Water bottle was completely pressurised and had thrown coolant out the expansion cap on the bottle
    Engine has covered about 800 miles and had also had three oil changes
  5. #555
    Non-member Logg's Avatar
    I had this problem last year it turned out the aei was shagged was pinking as the car built boost and on boost @ 13psi. Changed the aei and all was good.
    But other issues could be are the timing sensor wires the right way round? bb tuning did timing sensors that where like this brand new in the packet or have you chopped it and switched the wires your self? I use to do this while running a engine in to just make go a bit better@ 0 to stock boost levels. Might be worth a check?
  6. #556
    Non-member SCHWARTZ's Avatar
    Wallington south london
    What a cnut fella. Shame to hear that you have done such a good job with the car as well. Was you using that copper gasket in the end matey? As stated try another aei fully retard the timing sensor and see how that goes.
  7. #557
    From what Phil was saying on the phone yesterday the H/G used is a Payne type not sure if OK thickness or slightly thicker like uprated type yet.
    Phil, when you take it apart you will have to upload pic's of the gasket and the bores, and the head.
    Phil, I have a spare clio 16v coil pack matey, think you need to go mappable ingition
  8. #558
    Non-member 5teve L's Avatar
    RH12
    I still have the AEI off the Raider you can have Phil, let me know if you want it & I'll go over the yard & pick it up.
  9. #559
    Dartford
    Phil, you might also want to think about getting some wire rings machined into the top of the liners.. Only prob is, is it's engine out job
  10. #560
    Dec 2008
    tadworth
    stripped it down tonight and it looks like the cause is head gasket all steel liners are fine and pistons look fine just a bit black from over fueling head and valves all look fine aswell done a comp test a while ago and is showed that the cylinder second along from the water pump end was a lot lower like 30-40 psi lower and looking at the gasket it has a dented burn mark in it so would this of been why this cylinder was a lot lower on the comp test here are some pics you can see where the gasket has started going like an egg shape. this looks like it has been detting and i think its down to timming so im now on the hunt to see if i can get it efi'd asap so if any one has any efi parts they think they need to get rid of let me know what you have think i may end need to speak to scoff as im thinking of going adaptronic route
  11. #561
    Dartford
    Phil, there was an ecu and loom in the classifieds not so long ago,maybe worth a shot
  12. #562
    Dec 2008
    tadworth
    Ok car will now be off road for a while after deciding to go efi engine is soon to come out and have some more work done so hopefully it will be back up and running in a few months ready for next year quite excited now
  13. #563
    RH12
    Sounds good, how are you going to sort that engine to get the CR down though ?
    (sorry I missed your call, was busy at the time, I did try to ring you back mate)
  14. #564
    Going to be hard as the forgies and the block itself have all been skimmed down, and I know the chambers on the head have had alot of work shame to attack the head to modify the compression.
    Sorry Phil missed your call was @ Steve's at the time you called
  15. #565
    Non-member JRP's Avatar
    Nov 2001
    Hogwarts
    Hope your ok phil after your AnE visit looking forward to more updates.. ohh darts soon?
  16. #566
    Dec 2008
    tadworth
    Cheers mate I feel ok just a bit of a frightener with the old ticker looks like I need to have more tests done it looks like I have what me old lady has when my heart goes out if sinc one minute fast the next really slow but all is ok at the mo mate
  17. #567
    Non-member car.crash's Avatar
    Aug 2006
    You take it easy Phil. Best you stop climbing on jrp's roof now.
  18. #568
    RH12
    Glad you're ok mate.
  19. #569
    Dec 2008
    tadworth
    Ok a quick update a few goodies have arrived this week my adaptronic ecu wiring loom and 3 bar Cossie map sensor also got my brand new injectors yesterday siemens deka 550cc some more bits to be ordered on Tuesday so almost all the parts will be had within the next couple of weeks and then just be waiting on the manifold to be made so not to long I hope a big thanks to scoff for advice so far Will update when I have more parts and progress
  20. #570
    Dec 2008
    tadworth
    Ordered all the sensors today with scoff so will hopefully see them by the weekend also managed to pick up a brand new Bosch 044 original fuel pump today for a great price and treated myself to a bracket for it as well so all that's left to get now is a fuel reg and the manifold made and that should be me dine with the parts for the efi now I just need to think what way I'm going with the engine
  21. #571
    Sounds good and seeing the quality of your car i am sure it will be fantastic, still think you should ditch the c1j and go F7p turbo
  22. #572
    RH12
    I said that to him last night & he put the phone down on me
  23. #573
    Phil know's it make sense but I can see why he is sticking with the C1J after all the money he has thrown at the Big Jim spec C1J engine. F7 series engine makes so much sense I wish I had done it much sooner myself. You and revit hard Robbie need to take him out for a drive in your car's to show him what he is missing (well once you have finished yours that is).
  24. #574
    Dec 2008
    tadworth
    Ok guys there will be another engine once the c1j is finished but it won't be going in my 5 that's all I'm saying for now
  25. #575
    You need to convince your old man to let you have that williams sitting out the front doing nothing it's ripe for a project OE looks but engine upgrade
  26. #576
    Dec 2008
    tadworth
    Ok things are on the move again had big jim round last week looking at the best way to design the manifold he also had a look at the h/gasket that was on the car and it was the gasket itself which was at fault so nothing to do with high comp, fuel or timing any way engine came out last last cheers dave h for lending a hand so now going back to jim on Tuesday for another rebuild more head and cam work and to get the manifold mate so will update with pics when the progress moves forward about a month or so till I get it back
    Cheers Phil
  27. #577
    South East Regional Rep soapymech's Avatar
    central london
    got the adaptronic on yet?
  28. #578
    Dec 2008
    tadworth
    Quote Originally Posted by soapymech View Post
    Not yet mate but soon hopefully I have quite a few mods I can be getting on with though why the engine is away
  29. #579
    Dec 2008
    tadworth
    Ok engine now down with big jim went over to his unit today and dropped it off very excited for what other extras are to come from this little engine only time will see if it's all worth it I am dreading the extra pie and mash I'm gonna be spending though but oh well will be old and boring one day will try and keep this updated looking forward to seeing the inlet manifold design and now possibly loosing the current 4 branch exhaust manifold and going for a bigger one off design
    Cheers Phil
  30. #580
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    just looking at your gasket and pistons, not knowing anything else i'd of said there was water on the centre two cylinders being burnt, which usually would mean a warped head. make sure your head is nice and straight. and if you have had the block skimmed check the outer two cylinder liners arent protruding higher than the centre two. Im sure its all fine but its best to check
  31. #581
    Dec 2008
    tadworth
    ok small update after now deciding to go efi the main block has had all its extra work done and is now complete and is just in need of a few brackets and the inlet and exhaust manifolds to be made so should be looking towards the end of feb for getting it back and then the fun begins
  32. #582
    Good work phil
  33. #583
    Get ya finger out phill n get it down the meet
  34. #584
    Dec 2008
    tadworth
    Mate I'm gagging to get the lump back as when it's nearly there I still need to get it up to scoff
  35. #585
    Dec 2008
    tadworth
    new rims arrived today
  36. #586
    Non-member sieger's Avatar
    assen city
    Nice
  37. #587
    RH12
    Sod the rims, where's the engine & manifolds
  38. #588
    Cracking rims there fella.
    Now where's that engine.
  39. #589
    Phil looking good matey, pic of them on the car would be nice
  40. #590
    Dec 2008
    tadworth
    im gonna dummy fit them over the weekend on the car if all goes well ill order the tyres on monday as they have to come from germany for the make and size i want and then ill take some pics of them on the car when the tyres arrive
    THE ENGINE
    all the extra mods have been done to try and squeeze a few more horses out somehow and the lump is all built up and complete,the inlet manifold is almost finished and then it just leaves the exhaust mani to be done and some brackets fitted to finalise things so end of the month i should have it back home
  41. #591
    Sounds ace matey, defo make sure he puts a few brackets to hold the turbo up matey
  42. #592
    RH12
    THE ENGINE
    Sounds good..... we should have a wager... which red 5 will be finished 1st, yours or Marks
  43. #593
    Dec 2008
    tadworth
    me and mark have had a wager mate that both our cars are done before your back driving a renault
  44. #594
    Aug 2006
    so glad you got new rims. your old ones were pure aids.
  45. #595
    Dec 2008
    tadworth
    did you still wanna buy my old rims mate
  46. #596
    Aug 2006
  47. #597
    RH12
    I have nearly done the 172 just the fecking aux belt & having spare time to fit it
    Rims look good BTW
  48. #598
    Dec 2008
    tadworth
    Rims look good BTW
    Cheers mate and glad I could be assistance in finding you the 172 will it be at the next Surrey meet and will it make the fete day in June mate
  49. #599
    RH12
    Might be @ the next meet, depends if the wife has a class that night or not, can't remember when her course finishes, been bloody Weds nights though
    I'm not sure if it's a keeper though...
  50. #600
    Jul 2009
    lost
    i love those wheels wanted to see a set on a five for ages!
