Results 1 to 25 of 25
    Non-member bradzr5's Avatar
    Apr 2009
    North Shields
    turbo
    think my turbo is shot,
    the turbo will start to boost but doesnt have any acceleration in first gear, it is set up for 15 psi and reaches 10 in 2nd and all the way through. i checked the turbo the other day and there wasnt any play on the shaft. fecently had a problem with the oil feed and had to change it from the block. can only think that it hasnt had any oil to it and it is f@*#ed or something
    thanx for any help
    Apr 2009
    sevenoaks
    Re: turbo
    does it smoke,
    what you using to read and control psi,
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    Re: turbo
    have you checked for boost leaks
    Apr 2009
    North Shields
    Re: turbo
    were do i need to check for the boost leaks????
    got a guage in the car for the boost.
    had a leak with a dump valve and had to take it off could the line on that be leaking it is only blocked with a screw and tie rap
    Jan 2004
    BEDFORD
    Re: turbo
    Quote Originally Posted by bradzr5 View Post
    check the boost pipes the intercooler any vac piping
    Dec 2004
    Aylesbury
    Re: turbo
    Yes it could be mate, check that the vacumm pipe is sealed up nice and tight as any leak from the vacumm pipe to the AEI unit isn't good.
    Apr 2009
    North Shields
    Re: turbo
    why isnt it good??? never had a turbo car before.
    all a learning curve for me haha
    Apr 2009
    North Shields
    Re: turbo
    just checked for vacum leaks cant find anything at all, anywere i thought there might be one is taped up and still he same, there is a slight kink in the oil feed pipe dunno if that might be the problem.
    could a water leak have anything to do with white smoke and a smell of oil burning????
    thanx for any help
    Non-member markey b's Avatar
    Bury St Edmunds
    Re: turbo
    silly question, but have u adjusted the throttle cable so you have full throttle on the carb? easy way to tell is can you lift accelerator up as well as press it down? also press it down and hold it, then check the carb has no more travel on the linkage... its something silly but has been the fault with the last 3 cars i've looked at with similar problems!
    Non-member Maka's Avatar
    Mansfield
    Re: turbo
    thanx for any help
    are you saying that the exhaust has blue or white or any other coloured smoke coming out the exhaust?
    have you checked all intercooler pipe work to make sure that they are all on tight. One might have come slightly loose so you will get partial boost.
    like its already been mentioned check all the vacumn hoses for splits or holes.
    oil burning smell on tick over?
    is there oil leaking from the rear exhaust housing?
    http://www.youtube.com/watch?v=sTmG15EKuiQ
    does it look like that mwuahahaa
    Apr 2009
    North Shields
    Re: turbo
    same smoke but not half as much as that, and only does it every now and then not all the time.
    checked everything and sealed up anything i think might be leaking, does the intercooler have pipes below it????
    ya can lift the accelerator up and go down, will check see if there is any extra in the cable wen it is down fully. i personally havent tinkered with it but only had the car a few month, the choke is disconnected too dunno if that has anything to do with it.
    the oil feed to the turbo, were it connects to the block there is a bolt that has a hole through it (cant remember the name of the bolt) but this has only started since i changed it, could it not be lined up properly????? tried tweeeking it and the boost does get worse but never better.
    and is the car totaly not able to drive??? or can i make short journeys only reason is it is the only car in my house at the minute.
    thanx for all this help hope i can get this problem resolved soon cause i am missing driving her haha
    Mansfield
    Re: turbo
    that smoke is caused by my turbo loosing the will to live.
    smelt of burning oil, choked people half to death on the M1, left a nice blue film of smoke on my clothes and skin when driving and caused countless amounts of roadrage.
    slapped a new turbo on it and the car was completly fixed!
    Non-member UNICRONICUS's Avatar
    Jun 2004
    Isles of Scilly
    Re: turbo
    Can you take pictures of these oil pipes as it sounds like the oil feed to the turbo is shot, or maybe your oil pump is buggered...
    Apr 2009
    North Shields
    Re: turbo
    if ya go on my profile there is some pics there, think it is pointed out were the split was in the pipe. the bolt i am on about runs through it
    Jun 2004
    Isles of Scilly
    Re: turbo
    So is this pipe leaking quite badly when the engine is running and you rev the engine? I would replace this with a new pipe, or change the copper washers on it (if any) to make it seal properly again. They are called banjo connectors by the way.
    Apr 2009
    North Shields
    Re: turbo
    Quote Originally Posted by UNICRONICUS View Post
    already changed it all there is no leak now, but the banjo bolt has a hole through it could this not be lined up correctly????? hense turbo not doin wot it does best?????
    burton on trent
    Re: turbo
    I had this exact problem, turned out my turbo wasnt even bolted onto the manifold tight, it had came lose and there were missing nuts.
    Apr 2009
    North Shields
    Re: turbo
    was the turbo ok????
    Loose Bolts Tuning stuTHC's Avatar
    Dec 2005
    Leeds
    Re: turbo
    Ive just read in one of your posts that the choke cable has been removed from your car. Has the choke flap been removed? and if not is it held open?
    If nothing is holding it open it will eventually, over time with the vibration, work it's way shut.
    Non-member Mike_R5GTT's Avatar
    Sudbury
    Re: turbo
    Quote Originally Posted by markey B View Post
    silly Question, But Have U Adjusted The Throttle Cable So You Have Full Throttle On The Carb? Easy Way To Tell Is Can You Lift Accelerator Up As Well As Press It Down? Also Press It Down And Hold It, Then Check The Carb Has No More Travel On The Linkage... Its Something Silly But Has Been The Fault With The Last 3 Cars I've Looked At With Similar Problems!
    Lol Yep I No All About That Now
    Apr 2009
    North Shields
    Re: turbo
    Quote Originally Posted by stuTHC View Post
    had a problem with it over fueling it is held open now, but will check it, could the cause of all this be over fueling????????
    Apr 2009
    North Shields
    Re: turbo
    is there any1 in the newcastle on here that could maybe come have a look and give me a hand tryin to sort it please
    really miss not bein able to drive haha
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    Re: turbo
    what part is it within a turbo unit that is worn when you can move the shaft side to side a little..?
    also whats worn if the shaft can be pulled in/out a little.?
    ive got no in/out movement on the spare t25, just a little side to side movement and was think if an eBAY rebuild kit would sort this out.?
    Re: turbo
    In and out I believe is oil seals, a little side to side is normal and will fill with oil when in operation
    Feb 2001
    Rohtang pass
    Re: turbo
    ok, but what would excessive side to side play suggest.?
