Results 1 to 2 of 2
    Leeds
    Wrong part?
    Have I ordered the wrong part....
    Fixing my leaky sump with new seals this weekend, and am replacing the old hose from sump to oil feed (from bottom of the turbo). I have ordered a 22mm to 16mm reducer...is that right? or should both sides be the same size like the pipe under the turbo?
    Re: Wrong part?
    Depends what sump you have. The early ph1 sump has the smaller diameter pipe, the Ph2 sump has the bigger pipe. Measure twice buy once
