Results 1 to 47 of 47
    Saaaaarth East London
    Gay Fecked Tubular Manifold
    I bought this manifold from K-TEC about 3.5 years ago, it was on my last 5 before I broke it, and it's spent the last 2 years in my garage. It's covered about 3 thousand miles. I dug it out a couple of weeks ago with the intention of flogging it on ebay. To me horror on closer inspection I found the welds around the flange which attaches to the turbo have come apart. I went on K-TEC's website and found they have changed the design because this is clearly a common problem. All I can say is I was a complete mug for buying it in the first place. But is it repairable though?
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Re: Gay Fecked Tubular Manifold
    Just get it re-welded.
    j.d
    In the first picture the crack extends beyond the weld, can this still be fixed?
    Non-member Tiny Tim's Avatar
    Oct 1999
    Bournemouth
    I'd be wanting an exchange personally.
    May 1996
    Pie & mash shop
    Hello?
    Hello?
    I saw you post Mart and Agree just get it re-welded
    Yeah - me too. I've already contacted K-tec and they said unless I can provide a receipt they're not interested. I've looked everywhere for the receipt but no joy. c
    Oxfordshire
    Non-member BriC's Avatar
    Dec 2005
    Pfft - I'll be the first to say it.. just get it re-welded
    Aug 2004
    Bad customer service from K-Tec there.... they should have a copy of the transaction/sale to you as they have to keep records for 6 years!!
    Although technically the buyer should always keep a reciept... but K-Tec should be more helpfull. Its the product that has f*cked up.
    Oct 1999
    Bournemouth
    Quote Originally Posted by BriC View Post
    Good idea Briccles
    Oct 1999
    Bournemouth
    Quote Originally Posted by Penfold View Post
    Yep, they use Sage.. it'll be on record.
    I'll get it re-welded.... I just didn't know if that was possible. Is there anyone on here local ish to me who could do it?
    Oxfordshire
    password "letmein" by any chance
    May 1996
    Pie & mash shop
    Yep, they use Sage...
    If not, you're stuffed.
    Boom boom, tisch...
    Oct 1999
    Bournemouth
    Boom boom, tisch...
    Oh dear.
    Dec 2005
    Boom boom, tisch...
    Oh look.. Tumbleweed
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    as said they do keep all transactions on file. i had mine welded the other week not because of failure just to allow my inlet to fit but i was also going to have a bracket to made to take the weight of the turbo as this is were the problem lies
    May 1996
    Pie & mash shop
    At least that post wasn't 'invisible'...
    May 1996
    Pie & mash shop
    Same problem with the cheaper/ebay special Evo manifolds out there. They're great at first, but due to the lack of bracing, and/or the header walls are too thin (material wise), they crack after a few months use.
    Oxfordshire
    do you have the same invisible post problem with your new MLR chums?
    May 1996
    Pie & mash shop
    Funnily enough...
    Non-member Big Supes's Avatar
    Southampton
    It's pretty common for stainless manifolds to crack around the welds.... especially if the exhaust is supported by standard rubber mounts.
    Would you be up for selling it damaged??
    Mar 2009
    portsmouth
    ooo ooo, i'll buy it!
    Southampton
    Get in line then.
    Mar 2009
    portsmouth
    couldnt help myself but jump in then aswell!
    Just get it welded, should only be about £20.
    20 quid? - I might take it down the local body shop then. sorted.
    Mar 2009
    portsmouth
    Not sure the bodyshop is your best bet as they will probably only have a mig welder set up for mild steel, and the manifold is stainless, a local fabricators is where you want to go, usually down some old industrial estate, or a exhaust fabricators place if any local to you, but they probably will be less likely want to touch someone elses work. Good luck and dont get ripped off! Dont let the try it on and say it will cost loads, as it doesnt, only needs a clean up and a run of weld, they may recommend welding in a brace of some sort for the turbo like has been mentioned before.
    Jan 2004
    BEDFORD
    cost me 20 quid the other week and that included him cutting and splicing it about abit. he did comment saying the weld quality of the ktec manifold was actaully quite good i do have one of the later ones though.
    Non-member dingo22033774's Avatar
    medway
    help
    sorry for butting in need quick help any one know what order the valves go in to adjust the tappets. eg exhaust , inlet from the flywheel side of the engine. really am stuck cheers
    Jan 2004
    BEDFORD
    Re: help
    Quote Originally Posted by dingo22033774 View Post
    i think you need a haynes manual my friend. you can do them in any order if you like as long as you set each clearance when its fully open.
    medway
    have got 1 forgot it what valve is closest to the fly wheel exhaust or inlet
    Jan 2004
    BEDFORD
    its easy enough to spot but its the exhaust
    medway
    cheers m8 sorry im a bit of an ametur when it comes to car engines or computers
    Non-member rs250nut's Avatar
    The weight of the turbo wont help but the material used is **** too, if they used something like 316 it would not happen.
    Jan 2004
    BEDFORD
    what material are they using as it doesnt say in there description, and as far as im aware its only the weld that faild not the actual material.
    Because I spoke to a person who used to make them, plus look at the corrosion on it higher quality stainless with a higher carbon content wont do that
    Jan 2004
    BEDFORD
    so what material are they using then.
    Non-member tubby5's Avatar
    york
    my k-tec manifold cracked last week,the thing is i have had extra strengthing plates welded on the flange part plus i have a turbo support bracket and the fecker still crackedcheap crap springs to mind
    I dont remember because it was a while ago and there are loads of grades of stainless, just as a quick test does a magnet stick to it?
  41. #41
    Non-member jure's Avatar
    Split (Croatia)
    Non-member rhys0_0's Avatar
    Swansea
    Just get it welded. 5 min job. You can use stainless wire on a mig mind.
  43. #43
    Non-member tobester's Avatar
    Bracknell
    Whilst the manifold is off have a look at the area where the headers enter the collector, one of mine has just cracked out of there, also the flange the turbo bolts to has corroded slightly causing the two surfaces to leak when the turbo is bolted on, going to get that skimmed whilst it's off, and have a chat to the guy welding mine about some ott bracing around the collector area, knowing my luck once this is done the headers will crack out of the head flange. Maybe i'll have that done too...... alternatively just stick the standard one back on as it was fine for 20 odd years .
  44. #44
    Bracknell
    Determined not to have to take it off again!
  45. #45
    Non-member Boris's Avatar
    Nice. I would suggest checking the flange with a straight edge to see if it's warped before fitting....
  46. #46
    Bracknell
    Quote Originally Posted by Boris View Post
    done, needed skimming, wish i had supplied my spare head with the manifold bolted to it to reduce warp, hindsight is a wonderful thing!! thank you for the heads up Boris.
  47. #47
    Non-member FQ200turbo's Avatar
    Jun 2009
    Sintra / Portugal
    mine broke in the same place
