Fuel Pressure Regulator
Best way to get it off? Part number from renault? or can you buy one from elsewhere?
Committee, South East Regional Rep
Re: Fuel Pressure Regulator
Remove drivers side front wheel, Jack Drivers side of car up, place axle stand under car, get under the car and you will see just beside the brake servo the FPR I think it is held on by one bolt/nut on the bracket but I can't remeber the size (thining 10mm), the rest is just fuel lines 2 coming from under the car 1 return and 1 supply, the other 2 from the fpr will be vacum and the supply to carb lines.
I can can find you a part number when I get home from work tonight, with ref where to buy them from all depends if you want new or used.
Used CGB or phase 1 16v etcc
Or New Renault and I think Phase 1 16v has a renault account aswell
Cheers for the info mate. I will be after a new item, so the part number would be great.
