MATT C Ringworm Tuning
I may stand corrected here, but i tried a lot of oils over time and that mobil super s for the price beat it all hands down!! I was seeing over 100 deg temps at cadwell and still maintained above 40 psi oil pressure. Ive had some oils get way too thin and shat out of the exhaust at high rpm. Brigsy if pressure drops at high revs then flow will too. Doesnt sound like a blockage as the pressure is good at low rpm. The higher the revs the higher the flow and pressure needed. Could be the pump tolerances not close enough as and when the oils viscosity changes with temp.
