ok tried to turn the car over today after the full strip out and re-build ign light came on but would not turn over at all..... now i think it might be the alarm/immobilizer so im going to cut it out as how it was fitted before is a bit of a shame so my questions are as follows just to put my mind at rest.....
1, Main feed from battery to starter motor is this connected to the terminal on starter motor that shares the live feed that goes back to altinator?
2, where is the main (-) connection from the battery to the car as mine is just a short lead thats connected to the fixings on the rear bulkhead that holds the battery tray in
3, when you turn the ign on (not fully just so the dash light comes on)does the fuel pump operate? (as mine didnt)
4, either tach out or V+ in this picture https://www.rtoc.org/files/Technical%.../Scoff/aei.jpg was split and connect to the alarm/imobilszer (but it wasnt connected at the time to alarm/imobilser when i was trying to start it) why would this be ? and whats the relay that sits just by the AEI as is feed back to that?
5, the cable that is part of the loom by the AEI i stripped back some of the tape and it shows a purple wire that is joined to some white cable that goes into the engine bay now i got no idea where this cable was suppose to go as i had two ends in the engine bay so iu thought they just joined together...???
any other help that might explain the starter not even wanting to turn over would be greatly appreciated
Ian
