Results 1 to 30 of 30
    felixstowe
    electric windows
    my passenger electric window is not working since ive put a new door on. its the motor which came with the door. im thinking that maybe i put a drivers side loom in the door. or maybe if i did would the window still work?
    the central locking works though so maybe im way off and its just the motor...
    cheers
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    Re: electric windows
    Quote Originally Posted by tom t View Post
    cheers
    try the connector that goes to the motor with ignition on an pressing
    window button wiggle it about,may just be that
    Non-member BriC's Avatar
    Dec 2005
    Or if you want to check the motor do the following:
    * Get a car battery
    * Get two wires, preferably with crocodile clips on the end
    * Connect one end of each cable to the battery (obviously one on positive and one on negative)
    * Connect the other end to the terminals on the motor (once again, one on each terminal)
    * If the window is going the wrong way, switch the cable at EITHER the battery end, or on the motor
    If that makes sense?
    Non-member JRP's Avatar
    Nov 2001
    Hogwarts
    Quote Originally Posted by BriC View Post
    * Get a car battery
    * Connect the other end to your nipples* If the window is going the wrong way, switch the cable at EITHER the battery end, or on to your balls
    i get you
    Dec 2005
    safe blud
    Non-member tiff_lee's Avatar
    Glasgow/Lincs
    * Get a car battery
    Or of you're wedged and like gadets get a power probe!
    Dec 2005
    Is that some sort of vibrator or something? I'm OK thanks..
    Non-member i l k e r's Avatar
    Cyprus
    question is, is there any 5s out there with working electric windows
    felixstowe
    ive just connected a battery to the motor and the window works. tried holding the connector into the motor more that didnt work. whats my next step?
    cheers 4 ya help
    also after getting that one going up and down with the battery connected both of them wilkl be speedy little buggers when i get it workin properly lol
    Mine both work fine !
    Its just the rest of the car that fookt
    Dec 2005
    So it worked, or not?
    Glasgow/Lincs
    lol what, I dont know whats on your mind but i'm afraid not.
    You connect it up and it a probe/tester can provide 12v or an earth, good for testing electrics and fault diagnostics.
    http://cgi.ebay.co.uk/Power-Probe-3-PowerProbe-III-PP3-SNAP-ON-MAC-Tester-NEW_W0QQitemZ370109635946QQcmdZViewItemQQptZUK_Rec overy_Tools?hash=item370109635946&_trksid=p3286.c0 .m14&_trkparms=66%3A2|65%3A1|39%3A1|240%3A1318
    Nov 2001
    Hogwarts
    My editing of people posts in my quotes is so lost on this forum... whoooooooooooosh and over your heads
    Seems that way
    Non-member Russgt5's Avatar
    Nov 2008
    Shocking behaviour!
    Nov 2001
    Hogwarts
    Quote Originally Posted by Deano View Post
    Seems that way
    i knew people didnt read the quote part, when yoou highlight what other have said then comment, and ive prooved that today hahah
    Quote Originally Posted by Russgt5 View Post
    Shocking behaviour!
    Taxi for Russ !!
    felixstowe
    it worked when i connected the battery straight to the motor bric. but not when i disconnected the battery.
    Cyprus
    too much streoids
    Funny that, My phone is similar, when the battery is on it works, when i disconnect it it doesn't ? Go figure
    Nov 2001
    Hogwarts
    Quote Originally Posted by i l k e r View Post
    too much streoids
    No pure genius... read the 4th post in thread... actualy read it
    felixstowe
    i dont mean the car battery. im talking about the spare battery i connected straight to the window motor...
    Hehe ! sorry mate i think i've been hanging around here too long
    Seems like you got no power reaching the window motor, try tracing the wires back to find a fault ?
    Cyprus
    I did and I was guessing the steroids was the reason for your genious creativity
    Nov 2001
    Hogwarts
    ohhh hahahahahah no now the morph to the eeeeein is buggering me
    Dec 2005
    Have you checked the fuses? Either that or possibly damaged wiring, or a damaged switch?
    felixstowe
    havent managed to check the wiring yet. are the windows on seperate fuses then? as the drivers side is working. suppouse ill try my other side window switch with it then. cheers for ya help and ides much appreciated
    felixstowe
    i still havent sorted my passenger side window. ive noticed though when i have my lights on the light in the switch for the passenger window is alot dimmer then the drivers side.
    anyone have any idea why this would be? and cause this be linked to why the motor is not working? cheers
    Non-member TOMTOM's Avatar
    Jul 2011
    Where are the fuses for windows? My p/s has stopped working. Any help please thsnkyou ta
    Non-member Goobie's Avatar
    Mar 2002
    East Sussex
    Quote Originally Posted by TOMTOM View Post
    Under the glove box, your find the fuse box. The lid should show you which fuse is which. I think the windows are a 25 amp fuse?
