silly qestion realy, but wanna make sure its right
front lugs do i just pull out the tabs and that releses out side lug from inside, then how does the latch come apart? not had a close look tbh
Same as the front, just release the little clip with a screwdriver, might be easier remove the two screws holding the release bar at the back from the car
bar? well going to look at the car tomorrow, have a list of things to do, including a split hose on what i belive to be a return pipe from the inlet manifold to the pump above the temp sender. its right by the joint might get away with cutting and strecthing,
At the back what you use to open the windows with, they are held on by two screws, just undo those and you will see how that one comes apart easily. If its the hose im thinking of, replace it as they are prone to splitting as it is, let alone if you try and stretch it
How do you go about removing the rear window? I want to fit my perspex windows soon...
its all about the leveredge Chris, ......Just prizes out
i like to try and preserve the window im taking out
