Results 1 to 10 of 10
    Another wiring question.. what feeds the rev counter?
    is it a wire from the ignition module?
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Re: Another wiring question.. what feeds the rev counter?
    Yep, it's one of the wires (can't remember which one now...pink maybe?) on the 3-way plug/connector.
    Non-member bye_all_c_ya's Avatar
    walsall
    gray
    as im having trouble and i think it feeds large black plug over the rev gauge and cable slot no.8 i think may change to a brown wire
    Salford (manchester)
    The pink wire from the aei 3 pin plug.....letter C i think... ive seen these wires fade on some GTs but normaly its pink... the other two wires are 12v and earth so maybe use a tester if your colours are odd....
    Regional Rep Chris Hebden's Avatar
    Quote Originally Posted by Rob@Backyardracing View Post
    Nice find, will help me out alot , thanks!
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    where would you wire in a rev limiter there??
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    J, the rev limiter connects to the positive and negative outputs on the coil ( IIRC)
    They are two metal pegs on the side of the AEI, only one is just visible in the pic, just below and left of the supresser connection. To expose the other metal peg you have to cut away some of the plastic surround The limiter wires then slip nicely over the pegs once if they have female bullet connecters on them ( This it was Mart who suggested this originally, works well )
    THE BAT CAVE
    Quote Originally Posted by Kris M View Post
    cheers mate you just got yourself a wiring job..
    DONE!!!
    bracknell
    simpl;e innit
    the three way plug has three wires . one is earth thats gotta be the black one
    that just leaves two
    so if the yellow wire is B+ with ign on that only leaves one
    last one standing
    anyone fancy a game of cludo
    i recon it was pro plumb in the studdy with the lead pipe
