Results 1 to 33 of 33
    Non-member Nayls's Avatar
    Weymouth
    tubular manifold/b.m.s d/p fitting?
    Anybody managed to fit these pair on a gtt?
    did you make a spacer for the turbo elbow? or something else?
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    Re: tubular manifold/b.m.s d/p fitting?
    Quote Originally Posted by Nayls View Post
    ive got a tubular manifold on mine with a bms downpipe no mods required for me to fit mine but it was tight though
    Weymouth
    mine wont fit you'rs must be touching surely?
    Non-member jure's Avatar
    Split (Croatia)
    Mine fits like a dream. Its not K-tec manifold tho...
    https://www.rtoc.org/boards/album.php...pictureid=1667
    Mar 2004
    Coventry
    Spent WAY too long trying to fit an enlarged downpipe to James Surridge car, he has the ktec manifold and it is a ktec downpipe but no matter what I do it does not line upto the exhaust correctly
    Solution = BIG heat and BIG hammer to make a dent by the fouling downpipe to get the correct angle.
    Scoff showed me the light lol
    Looks a better solution than the stock elbow
    Jan 2004
    BEDFORD
    nope not touching (just 2mm gap)
    Dec 2004
    Aylesbury
    Are you running different turbo's to each other Richie and Nayls
    Jan 2004
    BEDFORD
    Are you running different turbo's to each other Richie and Nalys
    oh is it the turbo your refering to or the actual downpipe itself touching..
    Weymouth
    Quote Originally Posted by Duncan Grier View Post
    That's strange! because the car had a decent fitting k-tec d/p on with the manifold!! the b.m.s is a no go though
    so basically you dented it then? no point having an enlarged one on there if you're gonna do that is there?
    Non-member Adam L's Avatar
    Feb 2003
    SW London
    The other problem you may run into, when I fitted my v-band elbow a couple of weeks back was it might touch the water lines for the heater matrix. I had to re-route the lower one slightly, but my elbow is 3'' rather than everyone elses 2 1/2''.
    Non-member markey b's Avatar
    Bury St Edmunds
    Quote Originally Posted by jure View Post
    the d/p looks like the flange doesn't match ya turbo?!
    Non-member tubby5's Avatar
    york
    i also run a k-tec tubular manifold and bms downpipe and it fits perfect
    Weymouth
    im running a gt25r
    Weymouth
    downpipe is touching the manifold
    Split (Croatia)
    No, everything Ok. Flange is same as SS gasket. 5 bolt patern and exhaust housing is classic T2/T25 so do not see the problem. One bolt/hole is blank.
    Feb 2003
    SW London
    T2 and T25 stud patterns are totally different.
    Split (Croatia)
    My mistake. They fit on same 5 bolt flange. That was my point.
    Non-member Mr 5's Avatar
    newcastle upon tyne
    iv got the same problem, ktec manifold and bms dp, mine doesnt quite touch,but when hot i can only get a piece of paper between the 2 so its a tight fit
    Non-member Frix's Avatar
    is there gains to be had from a tubular manifold?
    Split (Croatia)
    I cannot tell since I changed turbo, downpipe, head, manifold, IC all at once. Cannot say is turbo more laggy (because of the its lenght) than before either
    Non-member Boris's Avatar
    As a product of mine is being mentioned, I'll add some additional information to the thread..
    Firstly, apoligies to the few who have experienced clearence issues with k-t** manifold, it appears the sharp angles on the first header closes the distance from d/p to manifold to within 5mm, although this seems to vary.
    When the prototype one-peice was made it was designed to fit around the cast manifold whylst still giving enough clearence to avoid burning the heater hoses.
    A well designed equal-length manifold could produce some gains,(nice examples from italy ect.) but over the years im yet to see much back-to-back proof on the c1j. Check Stuart Clark's engine for reference to benifits...
    I think a high percentage of the club feel there are more gains to be had from removing restrictions after-turbo, and so I was catering my product to the majority of people with an o.e. manifold in situ.
    Weymouth
    Boris,the downpipe is superb mate! in no way was i complaining at all mate (i know you've said nothing to think i was )
    it's far better quality than the manifold for sure! i was shocked when i shined a torch in the end of the manifold!
    Only reason ther manifold is on there is because it was on when i bought the car.
    Jan 2004
    BEDFORD
    i wonnder if just another turbo flange spacer could be made just half an inch that would take it away from the manifold wouldnt it. boris how much were the flanges to have laser cut mate this would be the cheapest option
    newcastle upon tyne
    thats what i was thinking
    When I had a large batch of flanges made they were about 15 each.
    I can enquire on monday about a small numer being made if required.
    Send me a pm if your intrested.
    Jan 2004
    BEDFORD
    boris just a thought have you concidered making some manifolds.
    Mar 2004
    Coventry
    On James 5 the ktec manifold is an earlier version and ktec modded it later on to get around the downpipe fouling issue.
    Never dented it in the end as James is going to go with another option - currently going to put his original downpipe back on for now (once the donut gasket turns up) could not stop it from leaking without
    On the ealier manifold you can get it to fit (with very very fine gap) but the angle it joins the exhaust is way off and does not seal. Also you have to loose the bracket which is really needed on the tubi mani
    Seems there are pro's and cons to tubi mani v's oe mani. I worry about lack of heat shielding on tubi - but I like to worry lol
    Weymouth
    why is the bracket 'really needed' ? i've had to remove mine
    Jan 2004
    BEDFORD
    are you refering to the bracket that takes the weight of the turbo
    Weymouth
    the one on the back of the block that goes between the downpipe & exhaust
    Mar 2004
    Coventry
    Bracket takes the strain off the tubi manifold - big turbo and full exhaust hanging off it is never going to be a good thing -
    Weymouth
    yeah i suppose it aint
    mmm what to do then? it would'nt line up with it on.
    york
    i had a bracket made up,it looks reall smart aswell a bit like the ones cossies have fitted i will get a pic for you
