Member
Re: Brake Master Cyl Question
In a word, YES...... ........but they can be, no, they will be a biatch and even worse to put back in. The other thing you need to do is, make sure the pin coming from the pedal correctly locates in the sleeve of the master cylinder. You'll understand when you pull it off.
I see. I did give them a lilttle tug and they seemed to be sat in there quite tight which is why I thought i'd ask first!
It's going to be fun!
East Midlands Regional Rep
Just did it on mine, the black pipes nearly fell out of the old 1 but took 2 of us to get them in the new 1
Committee, NW Regional Rep
As said they just pull out. Try not to remove the other end of that pipe (from the rubber elbows) I had all manor of trouble with mine cracking/breaking!
