Results 1 to 10 of 10
    Non-member RAL 5GT's Avatar
    Birmingham
    Alloy Radiators On Flea Bay
    Hi peeps i have been a member for a long time now but this is my first post so hello to everyone. Anyway has anyone purchased an alloy rad off e bay, its the one that a fella on there had a few custom made. i put mine on the car today and while on tick over the fan seems to cut in earlier but it won't stay on for longer than about 30 seconds, after about a minute it will come on again for 30 seconds. any one tell me if this is normal.
    oh yeh the fan cuts in at the first mark about a 3rd of the way up the temp guage and there are no air locks in the system, i also fitted a new fan switch at the same time 68/78 degrees.
    any feedback appreciated.
    Non-member TNT!hammond's Avatar
    Norwich
    Re: Alloy Radiators On Flea Bay
    problem i had with my fan continuously coming on was from heat soak . basically my top hose stat was 82 and the fan switch is lower than that so it always came on and off ,basically the rad never had water passing through it but the alloy heated up enought to turn the switch on. problem solved when i ditched the stupid low temp rubish and went oe now its fine .
    Non-member Tiny Tim's Avatar
    Oct 1999
    Bournemouth
    Let me get this right...
    You've fitted a fan switch thats rated at a lower temp than OE
    BUT
    You dont understand why its coming in sooner?
    Devils magic I tell thee...
    Birmingham
    sounds like the same problem here. whats the temp showing on yours when the fan cuts in with oe switch?
    thanks for the quick reply mate.
    Birmingham
    i know it will come in sooner tim but i had a low temp switch on before this one, only had to change it because the connector on the switch broke. but with the copper core rad and the other switch the fan used to come on at halfway up the guage and switch off when it was just below a 3rd, now it comes on earlier but does not stay on for as long.
    any ideas?
    Norwich
    78 deg on a standalone dash mate. basically you have changed from possilby a 92-82 switch to a 78-68 switch so it will be on erlier
    Norwich
    also my alloy rad cools quicker on my dash than the std item thus the fan is on shorter lenghts of time
    Birmingham
    cheers bud thanks for that
    Milton keynes
    Are these rads any good? they look nice in the picture???
    Non-member BriC's Avatar
    Dec 2005
    Nice thread revival!
