Results 1 to 26 of 26
    Non-member Blick's Avatar
    kidderminster
    missing manifold nuts!!
    got my carb off yesturday ready 4 a clean and service and noticed 3 nuts have come off the manifold on the turbo side!!! could this partly be the reason im having trouble goin above 10psi on boost??
    Dublin/Ireland
    Re: missing manifold nuts!!
    the nuts usually do fall off!! if your getting a popping through the exhaust on overrun then the gaskit is leaking a bit...as to weather its affecting your pref.on boost then it decides on how loose the manifold is??
    kidderminster
    i`ll get some new nuts on it asap!!! yeah 2b honest over the last couple of wks high up the revs she has been poppin abit...
    Oxfordshire
    if it's been loose you'd be as well to swap the gasket, chances are it's damaged.
    kidderminster
    cool! might aswell change that then while ive got the carb etc off, just ordered some heat wrap+ties also...... cheers
    Oct 2003
    anyone got the part number for the mani gasket?
    Here you go Adey
    77 00 855 962 GASKET MANIFOLD 11.52
    The price I have mentioned above could be well out as my diaologys are not the most up to date version.
    Dublin/Ireland
    R11800 From Gsf!
    Oct 2003
    thanks both of you awesome, is it easy to swap on the car? strangley ive only ever done them with the head off
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    Not too bad on the car Adey, abit fiddely but not too bad
    Oct 2003
    uve done it b4 mr m? might take a trip up for a hand with it if ure available?
    Non-member Nayls's Avatar
    Weymouth
    Reading
    Thats funny when i was doing my inlet manifold I noticed about three studs loose on the exhaust manifold.
    Apr 2006
    Swindon
    Yes mate, i did mine before xmas
    kidderminster
    Quote Originally Posted by Dan O'Neill View Post
    yeah i def put them on when i changed the engine vibration must have spun them off over time.....
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    it happens,just use some new binx nuts that will help
    Non-member scratcher's Avatar
    Milton Keynes - ish
    I struggled real bad doing it in the car.
    My exhaust manifold had extra metel though compared to other ones I've seen.
    Dublin/Ireland
    the later type manifold is webbed making the inlet hard to remove!!
    kidderminster
    anyone got any tips for changing the manifold gasket?? what needs2 come off etc: ordered 1 a few days ago.... its poppin like a ******* yet another job for the wknd ohh well! keeps me out of trouble.
    Milton Keynes - ish
    Get as much as you can out of the way mate.
    Carb, turbo, drop the down pipe, any coolant pipes and that
    Member clee's Avatar
    Derbyshire
    We have 4 full gasket sets in Shop stock that I haven't listed
    No head gasket ,but all others ,manifold rocker etc ....
    Meillor kit 016236P
    I can do them shipped for £20
    Or put a OE head gasket in with it for £32.50 .
    I only have 3 oe head gaskets left though .
    kidderminster
    Quote Originally Posted by clee View Post
    Meillor kit 016236P
    could of ordered that when i ordered my carb kit!!!! 2 late.... shall remember 4 next time
    kidderminster
    cheers!!! thought i may have2 get that lot off.... is it a right *******?? im off work friday now so i`ll get all that off thursday night ready for the mornin, then crack on with the cut knuckles
    Non-member gttjames's Avatar
    Cambridge
    Il be keeping an eye on this thread, gota do mine soon
    Milton Keynes - ish
    Its not really that bad Blick. My manifold has the extra webbing which made it an akward job, and it kept snowing, lots. Otherwise it'll be fairly easy. If you're doing the head gasket anytime soon it'll be even easier
    Oh, and mine left loads of the old gasket on the face of the head. I had to block the ports up and get a wire wheel and WD40 on the case. If you do this WATCH YOUR FINGERS!!! It hurts
    kidderminster
    cheers for that scratcher!!! ive gotta get it done.... sounds like a bad boy corsa merit with a 5" peco back box when you come off throttle.
