After market water gauge
im wanting to fit a aftermarket water temp gauge but use the existing sender.
as far im aware the original gauge runs from the connection on the water pump, looking at that sensor 2 wires come from it, having tested both with a voltmeter, both show 12 volts with the ignition on.
the gauges bundled sendor has 2 connections but 1 of which is ground, the other goes to "signal"
where do i connect the signal wire to? will eiather of the connections on the water pump sensor work?
if not where should i connect to or do i NEED to use the included sender?
Re: After market water gauge
would it not be easier to tap into the cylinder head end plate and fit a sender in there this is what i have done and is a accurate place to take the reading from
