Page 8 of 11 FirstFirst 1234567891011 LastLast
Results 351 to 400 of 515
  1. #351
    Ivybridge
    Re: Extra turbo.
    Brigsy, your van = SUB ZERO.
    Fact.
    What octane fuel do you run at the pod? Any additives?
  2. #352
    Re: Extra turbo.
    I use tesco 99 'momentum' with no additives, it will happily run on any super unleaded though mate
  3. #353
    Non-member IANMM's Avatar
    Sedgley
    Re: Extra turbo.
    brigsy pm for ya
  4. #354
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    Re: Extra turbo.
    super strength lager more like!!
    psssssssstttttttt o'clock!!
  5. #355
    Ivybridge
    Re: Extra turbo.
  6. #356
    Re: Extra turbo.
    Stella power ftw
    First snag fitting oilcooler tonight, the bolt supplied wont fit as mine is early ph1 block, but will fit ph2 no probs, they must have changed the thread for some reason
    Going to get it machined tomorrow to suit. Here are some comparison pics.
    O.e bolt
    New bolt
  7. #357
    Re: Extra turbo.
    After a bit of research turns out my block is 3/4 unf, is there any 3/4unf-m20x1.5 threaded adaptors available? or will it have to be a custom job.
    Thinkauto are sending out a 3/4 unf bout to fit but i will have to change the oil filter to something that will fit, i can foresee this been a carry on.
  8. #358
    Ivybridge
    Re: Extra turbo.
    Didn't Jeezus have the same issue with his Bean Coupe? Thats an early Phase 1 block too...
  9. #359
    Oct 2004
    Somerset
    Re: Extra turbo.
    he did indeed and thats exactly what he did , they often send / supply the wrong bolt...thinkauto will sort it , i remember they kept the info on their files like..., ask to speak to jeff.
  10. #360
    Re: Extra turbo.
    Which parts did you get matty? ive been talking to jeff & they have no adaptor to suit unless i change oil filter??
  11. #361
    Oct 2004
    Somerset
    Re: Extra turbo.
    i think it was a 3 -1/4 unf , the part i had originally didnt fit any block and it came with the kit..., hope that helps buddy , it was a while ago and loads has happend since..., get them to look up my order details... ref no:OR260498, in the name of matt clements, SEE IF THATS ANY USE, they will have sent some extras to me , the last one they sent...
  12. #362
    Re: Extra turbo.
    ill see if they can sort it, i can see this been a custom job though. If only i had a lathe & a good selection of die's id make my own
  13. #363
    Oct 2004
    Somerset
    Re: Extra turbo.
    shouldnt be buddy , they keep records so just tell them my name and order no....its just the wrong size , trust me , i tried 3 others before it..., get on that blower , any info needed just call me buddy, if i can help i will.
  14. #364
    Re: Extra turbo.
    Sorted finally, i got the hex head chopped off an o.e bolt & 3/4unf thread cut on the 'middle' to make an adaptor.
  15. #365
    Member Woznaldo's Avatar
    Canberra, Australia
    Re: Extra turbo.
    A simple solution, when you've got access to a lathe that is! Nice work.
  16. #366
    Re: Extra turbo.
    Van nearly ready for national day.
    Jobs done -
    13 row oilcooler & stat
    Renault extra 1.6d rad (ebay bargain nos valeo £35) - Holds stable temp at any speed/ambient temp finally
    Ian S charge temp gauge fitted - peak charge temps of 92deg at wot/flat out
    Innovate Lc-1/db gauge permanent install.
    Still have random mis-fire/occasional bogging. Had this problem since i fitted the piper
    285, no idea why as it starts & runs mint 90% of the time.
    I initially thought it was the needle jet playing up, but i have changed it with no joy.
    I have changed plugs, fuel pump, tank sender, fpr cant get to the bottom of it Possibly the b8's fouling up occasionally as my fuelling is rich at some points?
    Anyway i have given the old girl a clean up, needed a bit of tlc after a few months in garage.
  17. #367
    Non-member Logg's Avatar
    Re: Extra turbo.
    Looking good fella.
    Got to love RTOC tunning £35 rad jobs a goodun.
  18. #368
    Non-member scott 5gtt's Avatar
    May 2010
    stockton-on-tees
    Re: Extra turbo.
    Looking good mate look forward to a blast out in it. Cheers for last night running mint today just gouin out for a drive rack some miles up .
  19. #369
    Oxfordshire
    Re: Extra turbo.
    I'd put tyraps around all those silicon vac pipes. I did some bench testing of actuators a few years back, and at about 1 bar they started blowing raspberries
  20. #370
    Re: Extra turbo.
    Will do Andy, its on the 'to do' list They were all done but its been to bits a few times in the last couple of weeks.
    I recall my aei pipe flying off at 1 bar when i pressurised the system a while back, thats firmly zip tied on now!
  21. #371
    Re: Extra turbo.
    Jon, check the dizzy gear is neither 180 degrees out or one tooth out one way or the other... Shouldn't take long to check just to make sure.
    Btw, I wouldn't normally bother but that dash is a candidate for being sprayed - any colour than the current OE. Blurgh.
  22. #372
    Re: Extra turbo.
    Ill check the drive again but as far as i can remember it was correct. Just seems to be a random bog down in first at low rpm pulling away, if you rev it hard it clears its throat then its OK.
    Agreed dash/doorcards arent the best of colours got to fit my spare gtt dash at one point.
  23. #373
    Re: Extra turbo.
    Long time no update
    Well i fixed the bogging problem, new set of plugs and a regap to .5mm seemed to do the job!
    Shortly after the gearbox decided that enough is enough, diff bearings are making a horrible noise so im planning on rebuilding it myself over winter
    Mot has ran out aswell, after digging at a little rust scab on the o/s cill revealed that it has rotted from the inside out Never pick a scab eh?! Ive started the weldathon today, fabricating my own repair patches.
    Before - Grot fest
    Mid way, still needs a bit of work but not too bad for my novice fabircation skills. Does look a bit funny in pic think its the angle its taken, the patch curves to match the original cill OK. Will need a minor bit of filler but not the end of the world
    New sticker for back window too
  24. #374
    Re: Extra turbo.
    Time for another update.
    Welding is finished, Big thanks to Kris M for popping down & using his pmt welding skills to finish the job off.
    After some filler & stonechip, should look presentable going to finish off the front of the cill and get some paint on it next weekend.
  25. #375
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    Re: Extra turbo.
    No probs mate, looks good as new
  26. #376
    Non-member benj88's Avatar
    Mar 2010
    Re: Extra turbo.
    thats the game mate
  27. #377
    Re: Extra turbo.
    Finally finished the cill, not perfect but good enough for the van. Hammered a load of paint on with rattle cans and the finish actually flatted back well with 1200, half decent shine after a quick polish
    Hopefully get it in for mot this week and back on the road, cant wait
  28. #378
    Re: Extra turbo.
    Took it for mot on sat, straight thru no advisorys Back on the road finally.
    Need to get the gearbox changed asap, on its last legs at moment!
  29. #379
    Mar 2010
    Re: Extra turbo.
    Class mate
  30. #380
    Classifieds Moderator
    Mar 2004
    Re: Extra turbo.
    how many boxes has it killed? i take it there tired before they go in and then chuffed after a few months.. has it not got to the point where its easier to recon one than keep swapping?
  31. #381
    Re: Extra turbo.
    Ive broke 3 boxes last year Im frightened to spend strong money getting a box reconditioned to break it, tempted to pull one to bits myself and see if i can rebuild it.
  32. #382
    Dartford
    Re: Extra turbo.
    Vans looking coooool mate, top job
  33. #383
    Apr 2006
    Swindon
    Re: Extra turbo.
    Yes mate, glad to see the PMT welding delivered at the MOT
  34. #384
    Mar 2004
    Salford (manchester)
    Re: Extra turbo.
    Good stuff pal
  35. #385
    Re: Extra turbo.
    Cheers all
    Have been pretty busy over the last week, gearbox finally died so had to sort it.
    Here we go again..
    Nice metal filings in box, gear oil was silver when i dropped it out?!
    All back together with new box (Thanks to the man Kris m!), spot the subtle differences. Done away with the degas chamber on the cooling system, seen this mod on Rob@backyards ph1 & Scoffs old c1j setup.
    The cooling system is very simple now with no carb base/inlet cooling, only needing seven hoses in total. Its very similar to the ph1 setup, works absolutely fine.
    I have also painted the inlet manifold heatshield with crackle black paint and have blanked off the port in the middle of the carb body for the actuator.
    The actuator is now plumbed into the port on the end of the compressor housing. I was never too keen on the petrol vapour coming out the bleed valve right above the exhaust manifold, it certainly destroyed the old silver paint on the inlet manifold heatshield over a few miles!
    Carb looks quite minimalistic now with only fuel hose & hose on the end of the enrichment block, ideal if i need to remove it to rejet. I have also renewed the engine wiring loom as it was tired & have generally cleaned up everything. Chrome parts have had a good bufty up
    Next mod is .63 back end on the t28 & see if i can up the boost to 25lbs
  36. #386
    Mar 2010
    Re: Extra turbo.
    Beast
  37. #387
    Re: Extra turbo.
    Had the van on the weighbridge earlier. 920kg with a few tools and 1/4 tank of juice, 1000kg with me in it. Not as light as i thought it was!
  38. #388
    Dec 2004
    Aylesbury
    Re: Extra turbo.
    Thats perfect weight for the Outlaw Shootout drag race or the ESC mate!
  39. #389
    Re: Extra turbo.
    I'd be up for it if I had a couple more hundred ponies
  40. #390
    Mar 2004
    Re: Extra turbo.
    Hmmm, can we see an engine conversion?
  41. #391
    Dec 2004
    Aylesbury
    Re: Extra turbo.
    Not all about the ponies, there's one Civic entered that only does 13's. Although think you could squeeze a few more out of it!
    Think it'll be about consistancey and getting off the line, also its HKS day before so maybe few of them will have issues from that!
  42. #392
    Re: Extra turbo.
    A few more cc's & 16v might be on the cards soon
    Might try and up the wick a little bit on the current setup for this season mark, might be a few more ponies in there?? Still havent upped the boost over 22lb yet, need to pull my finger out and do some more mods to stop the float chamber emptying! 2.1mm needle is not enough.
    Tryed a set of kris m's cup steels on at the weekend, need to get mine refurbed & fitted for the bog standard van look! Cant decide on silver or white powdercoat though??
  43. #393
    Non-member modfather's Avatar
    Re: Extra turbo.
    im loving those tyres what model are they, i see that they are michelin
  44. #394
    Dec 2004
    Aylesbury
    Re: Extra turbo.
    Track slicks from what it looks like mate
  45. #395
    Jul 2009
    lost
    Re: Extra turbo.
    where do you find a set of cup wheels?would love a set!the van is ,well , o my god,amazing!good effort all the way! what a great bit of fun!
    lot of respect for doing it!
  46. #396
    Aug 2004
    Re: Extra turbo.
    Quote Originally Posted by r5_scotty View Post
    Cup wheels are very rare and expensive.... different ofset to standard steel wheels, came from the Renault 5 cup car series....
  47. #397
    Jul 2003
    Re: Extra turbo.
    Quote Originally Posted by Penfold aka The Dealer View Post
    (Let me guess THE DEALER's next post)... It just so happens I've got a set somewhere I could let you have for a few £££
  48. #398
    Aug 2004
    Re: Extra turbo.
    Lol sold my 3 sets with my old cup car....
  49. #399
    Re: Extra turbo.
    I got my set off Sam Fish ages ago, just need to pull my finger out and get them refurbed.
    If they weren't so rare id get them banded out to 7" wide. Im actually tempted to get a set of gtt spare wheels banded for the deep dish steel look like the pair i have for my drag radials..
  50. #400
    Non-member gtmatt's Avatar
    manchester,sale
    Re: Extra turbo.
    amazing work mate happty days
