Results 1 to 9 of 9
    5 Distributor V 5GT Distributor
    Are these the same? Is it worth nicking? TA!
    Non-member i l k e r's Avatar
    Cyprus
    Re: 5 Distributor V 5GT Distributor
    if you're talking about the n/a 5 only the late models with an AEI unit will be suitable I think...
    If it looks the same as a gtt distributor it will work fine, i used a 1.4n/a distributor years ago.
    Quote Originally Posted by i l k e r View Post
    Well it looks identical to the one I have, the car has an aei in the position of th ph1's and looks to have single point injection if that helps?
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    it'll work fine, dont worry
    I am thanking you all for your help!
    Honorary Member RichR's Avatar
    York/Selby
    As other have said - if it looks the same, it'll be fine. But stay away from the dizzy used on the 950cc and 1.1 litre Renault 5s, as they' have points for the ignition advance rather than an AEI unit. You could probably just ignore the LT side of things and only use the HT bit, but it'd look a bit odd.
    And I wouldn't try to get the dizzy off the 1.7 litre engine to fit a GT Turbo, it goes on the end of the camshaft
    Quote Originally Posted by RichR View Post
    Rich wouldnt the points system be used on the older 5s? This is an Lreg with an AEI and automatic choke
    York/Selby
    L-reg is positively modern! Points dizzies are on the 1985-1989 (ish) 950cc, 1108cc and I think 1397cc Renault 5s (yes, Supercinq shape) - TC, TL, GTL etc.
