Results 1 to 10 of 10
    burton on trent
    how to remove steering wheel
    how does a r5 steering wheel come off, i removed the centre bolt but it seemed pretty firmly fixed still and i didnt want to rag to hard on it.
    Non-member JonnyGee's Avatar
    staffs
    Re: how to remove steering wheel
    put the bolt on for a couple of threads to stop u breaking your nose then sit in the drivers seat and rock the steering wheel as u pull as it will be stuck on the splines should go eventually
    Non-member jure's Avatar
    Split (Croatia)
    Pull like a maniac and watch out not to knock yourself out. Just pull. HARD!
    Non-member Blick's Avatar
    kidderminster
    yeah they r abit stiff! un do the nut and pull like ****
    Non-member Kenobi's Avatar
    Jul 2006
    Leicestershire
    To save you the effort hit yourself with a bat in the face then drive round mine and we will get it off.
    As opposed to on. Coz i aint like that.
    Non-member Gttnutter's Avatar
    Oct 2005
    Amersham
    I've tried many of times to pull mine off and it dont budge for nothing
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    The trick is to not pull, it won't go anywhere. you need to whack it from behind on opposite sides in turn. In other words, with your palm or a rubber hammer you need to hit the outer edge of the steering wheel from behind, left hand side then right hand side repeatedly until it free's off. Leaving the nut on a couple of turns will save a lot of pain, as mentioned.
    Non-member Nick k's Avatar
    Leicester
    Quote Originally Posted by kenobi View Post
    to Save You The Effort Hit Yourself With A Bat In The Face Then Drive Round Mine And We Will Get It Off.
    As Opposed To On. Coz I Aint Like That.
    Lol
    Non-member Karlos's Avatar
    Apr 1999
    Leeds
    Or just dig a three leg puller from your tool box
    burton on trent
    got the wheel off, thanks folks.
