Results 1 to 5 of 5
    Squeak Noise
    I have finally got my car to idle properly tonight many thanks to 5teve L for the carb.
    Now after taking the car for a good run tonight I seem to be getting a really weird squeking noise from the engine bay on the passeneger side like a bolt or metal is rubbing which causing the squeak. I have checked all bolts and none are loose, anybody got any ideas??
    Non-member Tiny Tim's Avatar
    Oct 1999
    Bournemouth
    Re: Squeak Noise
    Just retrace everything you've touched first. May be unrelated though, you know what these things are like!
    Not the belt stop on the water pump below the degassing chamber is it?
    Re: Squeak Noise
    No it's not that Tim it's coming from the other side of the engine. Only does it once the engine is warm
    Bristol
    Re: Squeak Noise
    I had a noise like that turned out to be the release bearing.
    Re: Squeak Noise
    Quote Originally Posted by Badge View Post
    Release bearing is on it way out as that has got a noise, I think i may have sussed it now the engine and exhaust has all cooled down. Been out in the dark with a torch looks like the D/P bolts thread has split this could be a the problem becuase if I rock it hard to squeaks like the noise i hear when driving.
