Results 1 to 20 of 20
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    baffled sump
    is it worth having one on a road car,or if the car is
    to be tracked alot?
    Non-member jure's Avatar
    Split (Croatia)
    Re: baffled sump
    No need for it really. Sounds cool but with appropriate oil level even on track isn't essential.
    Trader
    Big Jim Racing
    Chadwell Heath, Essex
    Re: baffled sump
    Quote Originally Posted by jure View Post
    True enough. Personally though I really don't like big open sumps like the 5 has. The oil may not move around enough to uncover the pickup (although with softies on I can't imagine that would be too difficult!) but it does slosh up into the path of the crank and I just don't like the idea of effectively sticking your oil in a blender, aerating it and damaging your viscosity modifiers etc... Therefore I do like to baffle, but more as a means of controlling were the oil can move to rather than trying to hold it in one place, if that makes any sense?
    Re: baffled sump
    I gotta go with Big Jim, I perfer to play it safe when it comes the oil and coolant systems
    Aug 2004
    Re: baffled sump
    And how many head gaskets you gone through Only joking, how is the beast?
    Re: baffled sump
    Quote Originally Posted by Penfold View Post
    Head gaskets aren't killed directly by oil issues.
    The beast as you call her is under going a major engine revamp and alteration, namely New bottom end build with a new engine colour scheme, a custom tubular manifold, external wastegate and some other little bits and pieces, saw ya thread on ya new cup, looks good, you gunna bring it to Nat day?
    4
    Member clee's Avatar
    Derbyshire
    Re: baffled sump
    Are we getting all blinkered again and talking 5 tech
    I know the GTA would benefit from a baffled sump I must lose half a liter out the dipstick tube every time I go out on track
    Anyone who's ever been behind me will testify ........
    Non-member Tiny Tim's Avatar
    Oct 1999
    Bournemouth
    Re: baffled sump
    Quote Originally Posted by clee View Post
    Yeah, I saw you polluting at Mallory. Filthy habit.
    THE BAT CAVE
    Re: baffled sump
    but what real damage/failure could occur if a baffled sump was
    not used,if any?...and unless the oil was very low would the oil
    pump just be sucking in air?
    Re: baffled sump
    Funny though
    Derbyshire
    Re: baffled sump
    Laugh it up mini-skip boys ......I've got 7.5 liters in my big ole sump so I don't think starvation will ever be a problem .......It could do with being restrained a tad though
    Re: baffled sump
    Lots of nasty things, if your pump is sucking air and not oil it could starve your turbo of oil leading to shot bearings and maybe oil seals or knacked blades as they hit the inner housing.
    It cause wear on ya main and big end bearings, which we all know is not good.
    Your cam could excessive wear which could cause issues, haven't had any cam issues me self yet so I can't say what.
    THE BAT CAVE
    Re: baffled sump
    dont want that happening,i have seen various different sump
    configurations,some very opposite of the cup sumps,using
    vertical sections placed at various locations..guess other cars
    have different pump locations?
    Re: baffled sump
    That lot is of course worse case sinario, I dunno exactly a baffled sump needs to be layed out, I just got a standard renault ph1 job and been done with it
    Feb 2009
    Walsall
    Re: baffled sump
    well i rekon they work in a way..
    but iv read somewhere before that if you havnt got one. on track days just top the oil up abit more than the usual. this compensates for the loss wen flying it around..
    bracknell
    Re: baffled sump
    Funny though
    but beutiful
    clee it's down to the big flat sump innit even the 25t can pick up oil on heavy braking and cournering (bendy bits)
    Non-member Adam 005's Avatar
    Dorset
    Re: baffled sump
    to be tracked alot?
    No real need for a baffled sump on the road as you never tend to say in corners for a long time unless you like going round round abouts alot.Baffled sumps are a good idear for track use as you tend to push the oil to one side of the sump as race tracks tend to have many turns in one direction
    Derbyshire
    Re: baffled sump
    Quote Originally Posted by THE MASTER View Post
    but beutiful
    25 sump is about an inch shallower than the GTA ali sump .I was wondering whether to put a 25 sump and pickup tube on the GTA Why they do this anyways ???
    Would I get a lot of froth with the level up nearer the crank ???
    THE BAT CAVE
    Re: baffled sump
    froth lol you make the old gta sound like a coffee machine!!!
    Derbyshire
    Re: baffled sump
    GTA latte ...Available now in the SHOP
