Results 1 to 25 of 25
    Non-member newbstar*'s Avatar
    canterbury
    After a run in my 5 pulled up at home then the car started to misfire badly and cut out.The vehicle would only restart while pumping the throttle.Fuel you think, well 4psi to carb 2 carb changes no better. Ignition tdc change ,aei change spark is present different cap rotor leads.Found air leak at inlet manifold stud,removed head to helicoil it refitted new h gasket kit and bolts. Compression tested b4 and after this all results good.There was no wash on the head or pistons present no visable damage anywhere?Checked dizzy was turning ok thats good too,different fuel pump relay checked fuses.The model is a 1.5 i beleive e reg,aei in scuttle cant see any overboost wires did this model or the phase one have them.Any help on diagnosing the fault would be great cheers.running out of patience jason.
    Non-member Mudslinger's Avatar
    Feb 2003
    Re: ????
    new sparkplugs might resolve this , maybe 1 of the leads is causing the missfire
    Feb 2009
    Walsall
    Re: ????
    ye try the leads mate, if not try replacing your dizzy. saw a 5 before, bloke put a new one on stil didnt wanna run.. changed it again and it worked :S wierdd lol..
    canterbury
    Re: ????
    Quote Originally Posted by Mudslinger View Post
    read closer mud
    canterbury
    Re: ????
    Quote Originally Posted by newbstar* View Post
    read closer mud
    plugs changed car just wont start now spark an fuel there, possibly ign timing?
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    Re: ????
    are the plugs wet were you have been cranking. is the diizzy cap sat correctly and located with the little lug if it has one and check the dizzy cap has the centre prong still inside it.
    Jan 2004
    BEDFORD
    Re: ????
    and this is also pressuming you have set you valve clearances correctly
    Feb 2003
    Re: ????
    read closer mud
    i cant make out in your paragraph where you say you changed the plugs or leads
    nevermind i go back to my
    canterbury
    Re: ????
    valve clearances done correct, dizzy turns as should. Managed to get it running ,but still have to pump the trottle/make the accelorator jet work to start.The car will not idle and you have to to hold the throttle open,car dosnt seem to want to rev too high though? Cap and rotor good.
    Jan 2004
    BEDFORD
    Re: ????
    is the mixture screw still in situ
    canterbury
    Re: ????
    yep mixture screws there. carb is not at fault tried 2 known working items.
    Non-member Duncs's Avatar
    Europe
    Re: ????
    area the breather restrictors in place?
    Jan 2004
    BEDFORD
    Re: ????
    i would suggets a air leak.
    canterbury
    Re: ????
    Quote Originally Posted by Duncs View Post
    No breather restrictors inline at all ,but neather had any to start with.
    Re: ????
    Dodgy one way valve on inlet manifold? Servo leaking?
    canterbury
    Re: ????
    leak sorted as per first post ,and this wouldnt make it that difficult to start. What would a blocked fuel return do on the 5?
    Re: ????
    Blocked fuel return would probably make the fuel pressure really high.
    canterbury
    Re: ????
    what are the wires down near the starter for as starter motor done about a month ago,possible melted wire down there.
    Re: ????
    The thin grey wire that goes from the gearbox is for the speedo, the other two relate to starter only. None of them will cause problems like yours.
    canterbury
    Re: ????
    tought there was nothing that relate down there on the loom.
    Europe
    Re: ????
    earth straps ok ?
    canterbury
    Re: ????
    earth straps ok ?
    yeah did volt drop test on both of them ,both ok.
    Tipton
    Re: ????
    are you running a vernier pulley on your cam...it might have slipped?
    Non-member Nick k's Avatar
    Leicester
    Re: ????
    Your car may have developed a condition called Raj fever.
    canterbury
    Re: ????
    possible as dont know the full engine spec and neither did previous owner.The head was ported and had larger inlet valves, bronze guides.
