Skoff da-man dats who
Gta Jil is all booosted up to the max .Bigger injectors in and running a bar .
All going well and lovely smooth POWER .
Thanks Chris once again
It just needs a TO4 now !
I'll have words about that ....If I can get one at a reasonable rate
I've emailed that wiring info ....It is wired as I described .
All 6 pins A from each injector go to a single A and pins B to a single B in the std loom then to a pair of paired outputs A & B from Adapt
I know what I mean .....
Ah, the diagram you sent me just now says that there are 2 injector wires that come down to the original Renix unit. The 4 outputs from the adaptronic have been bunched into 2 pairs, ie pins 5&6 make one pair and pins 7&8 make the other. You effectively have 2 high current outputs from the ECU then instead of 4. These are then connected to the 2 wires in the Renix loom. That's fine because each of those wires in the renix loom will feed the -ve side of 3 injectors. The +ve side of all 6 injectors will go to ignition live. It sounds like it is wired like this:
Which is fine.
That's alright then
See that's what happens when I think out loud ..I'll stick to drawing up little bits of plastic .
You can keep the CC Dave ,my twin air cooled mod works just fine,weighs nowt and cost less than the antifreeze in the CC
I'm using the car for track but will want something for the odd blast up the strip .I've got the 60trim cossie that Adam will refurb and the std GTA one that's on at the minute .
0.48 turbine housing for both at present .I build these up on seperate collectors so can just swap quite quickly .
Another complication is another engine on the way with some head mods and cams .This could do with something like the T04 ??
Stick a 21 engine in, you can have 250bhp with no mods
It's gone up again
If I'd wanted a kitcar Id buy an Ultima
The BHP on that 21 engine
Stay away from the tanning beds Dave, its messing up your brain.
I saw it on facefook Dave, you huge gay
Do I get any extra points if I point out its actually a 320 AMG 6 speed manual?
No...
Beverly Hills Hairdressers car
Weeeeeeeeeeeeee!!!
You ****, the head is not to scale.
Make it bigger.
Have you worked long at Adobe as a Photoshop demonstrator?...
Actually I work for Microsoft in the 'Paint' development department. Been on my own here for some years now
