Results 1 to 7 of 7
    Non-member Misky's Avatar
    Oldham, Greater manchester
    Fuel filters
    Where do you get yours from?
    I bought one with some other stuff from a local bms store.
    Its a 'Fram' filter, but it is tiny compaired to the original.
    Its one of the them clear plastics jobs with an oranage carboard filter.
    Will it do the job?
    Non-member Tiny Tim's Avatar
    Oct 1999
    Bournemouth
    Re: Fuel filters
    They're only good for stivking in-line to the carb, but are a total fire hazzard... no good for the main filter under the car.
    Go to GSF/ECP for a proper filter, they cost feck all.
    Re: Fuel filters
    Cheers for that tim, Last thing i want is is setting on fire after all problems I have fixed so far.
    Non-member Nayls's Avatar
    Weymouth
    Re: Fuel filters
    Phase 1's have the plastic filter underneath,well all the one's i've had did anyway.
    Non-member tobester's Avatar
    Bracknell
    Re: Fuel filters
    Quote Originally Posted by Misky View Post
    Will it do the job?
    Plastic ones are ano-no IMO, the number you have is probably Fram G12-1, that is for N/A engines, the no. your after is Fram G3829, or Mann amd Hummel WK830.
    Re: Fuel filters
    Cheers pal!I believe you are correct!
    Bracknell
    Re: Fuel filters
    No probs.
