I cant seem to get my boost over 15psi(carb top), the actuator is wound in as far as possible. has anyone got any suggestions?
Actuator to weak to hold any more boost try dare I say it putting a bleed valve in line
yep bleed valve worked mate nice one, whats a good after market actuator to go for??
You got yours running yet
over boost is not touching are they ? silly idea i know but you never know
Is this a classic?? Standart T2 pushing over 15PSI??? wont last will it??
No its a t25/t2 hybrid. Only running 18-20psi Carb top so should be safe fueling is spot on as well.
