Results 1 to 6 of 6
    Jun 2011
    flat spot when changing gear or cornering
    Hi folks its prob been asked before but my 5 has been gettin worse now for a wile and its just when your off the throttle then when you go to press it again when coming out of a corner theres nothing there like a big flat spot its really annoying because its as if u turn the key off and it then kick back in with a thump if you get me. Now my afrs have started creaping up its really bad when cruising alone it has started going off the scale and on boost its 10.5 ish any pointers would be great thanks in advance👍
    Non-member tubbyG's Avatar
    Dec 2010
    Re: flat spot when changing gear or cornering
    Carb could probably do with a strip down and rebuild. when was it last done?
    When my 5 was on the road I would do it alteast every 2 years or earlier
    Feb 2015
    Quote Originally Posted by Muzza View Post
    I'd be checking fuel pump and filter, perhaps whip carb off and give it a good clean or even refurbish.
    Norwich
    Sounds fuel or carb related, fuel pump & filter ok? Accelerator pump on carb nice and free?
    Jun 2011
    Just ordered the rebuild kit so will wait on that coming. I have a run to do with a club i done last year now on the 4th of september so mite hold off until after that then get the carb striped. I done it about 4 years ago no idea what size of jets is in there so wil get a micro bit set wen im at it and take it from there cheers folks.
    Likes Trevhib liked this post
