Im after some new or 'used but good' Axle bolts, the ones that join the axle to the chassis. 4 in total but I believe 2 different sizes.
Let me know what you have
Renault still sell the shorter ones but they're quite expensive. The nuts are NLA.
I brought new nuts not long ago
Yes, should of said want nuts as well
So maybe best looking for 2nd hand ones
Both bolts are still available. Part numbers in Dialogy with updated numbers.
I'm not sure, it was October last year? The numbers for the bolts were spot on it was just the nuts that I was told were NLA.
Incidentally the clips/brackets that's go on top of the bolts are still available. They're a new design but work the same way.
I was told the same when I last enquired about the nuts at Renault.
iirc m12x1.25 pitch built in washer and nyloc if you cant get them anymore
Ahh the nuts, cant see why those are discontinued as they are just normal nuts with lockslip on them
You can purchase flared nyloc nuts from ebay,in stainless to!
i replaced most of my wishbone and shock nuts with them.
