Results 1 to 4 of 4
    Non-member tubbyG's Avatar
    Dec 2010
    Oil pump
    Does anyone have experience with this:
    http://www.ebay.co.uk/itm/RENAULT-5-...YAAOxypNtSenxi
    Looking to see if it will provide enough flow/pressure.
    I have read that some aftermarket pumps are actually campus types - hoping that this is not
    Super Administrator R5MJH's Avatar
    Feb 2011
    Down South
    Re: Oil pump
    yes i bought one of these for mikes c1j when he had it from cgb does a great job but i found the shaft so tight after fitting it needed manually turning with mole grips until loose also i was advised by machine shop to use a small smidge of vaseline to bed in when fitting , this worked a treat
    hope this helps
    Non-member GTphil's Avatar
    Re: Oil pump
    The campus pumps are a gear type design. The GTT is vein and rotor as in the link
    As Mick says pack it with Vaseline before fitting, or failing that engine assembly lube.
    This will help it pick up the oil initially.
    Dec 2010
    Re: Oil pump
    Just what I was hoping to hear.
    Thanks guys
